Author Topic: Ill-Advised Super Sport (CB750-F0)  (Read 21544 times)
Re: Ill-Advised Super Sport (CB750-F0)
« Reply #150 on: January 26, 2019, 11:29:38 AM »
This sucks given all the work you put into your bike.  As the others said, you can swap just about any SOHC750 into that frame.  The 69-76 motors will require the least amount of compatibility issues.
« Reply #151 on: January 28, 2019, 07:55:20 AM »
Sorry to hear.   I'd look for a replacement engine, they can be found relatively cheap
Offline SHORTROUND
« Reply #152 on: January 28, 2019, 12:34:12 PM »
I have a spare used head complete. Probably cheaper than an entire engine.
Offline Jessamine
« Reply #153 on: April 09, 2019, 06:47:18 AM »
Hey y'all! I have a work van now (an E350 I nabbed for $100 because it had a differential oil seal leak, lol), and a line on a couple local, complete engines out of running bikes. I have the option of a 1976 K for $150 that's 45 miles from me, or a 1972 K for $200 that's 85 miles from me. Thoughts on which I should spring for to get this bike back on the road? Super Sport engines comparatively uncommon, it seems.
1975 CB750F
1986 CN250
2005 KLR650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #154 on: April 09, 2019, 08:39:18 AM »
1975 CB750F
1986 CN250
2005 KLR650
I can't think of any reason to spend $50 more dollars and drive 80 more round trip miles to get the K2 engine.
« Reply #155 on: April 09, 2019, 09:59:19 AM »
K2 tends to be worth a bit more.
 Ask questions about chain damage .. and try to inspect that area , and fin damage.
 And check around lower edge of point cover for damage or repair.
Not so bad if those gave been fixed properly  what you don't want us cases welded together.
 rear motor mount above chainare sometimes welded, and the main bearing bolt bosses just past the point area  those areas take the hit in bikes that get written off.
 And the wurst , oilfilter thread damage m but that is quite rare.
And often you see mismatched top ends.           Good luck
Offline Jessamine
« Reply #156 on: April 09, 2019, 01:11:05 PM »
I will say the 76 is painted black (and that paint is peeling) despite being a K engine. It is whole with the oil tank and everything else though, whereas the 72 is totally disconnected and also has no starter cover.
1975 CB750F
1986 CN250
2005 KLR650
Offline Rudetex1981
« Reply #157 on: June 02, 2019, 05:33:48 PM »
Anyone have a 77 cb750f tank for sale?
