Author Topic: CB750 AHRMA Superbike Heavyweight Racer  (Read 38759 times)
Offline Tintop
Re: CB750 AHRMA Superbike Heavyweight Racer
« Reply #100 on: August 17, 2018, 04:39:41 PM »
the spondon calipers used the same seals and pistons as the ap calipers so no problems there, the ap adjustable ratio master cylinder is just a standard master with a crude slider that alters the leverage they dont work any better or worse than normal one . the leavers used to cost a fortune though . master cylinder ratios were understood perfectly well in the 70´s my rg500 came with 3 size options depending on use .
Interesting, and would make sense given they are both from the same period.  Question is....Is Chris @ MotoGP using the AP parts as well?
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #101 on: August 17, 2018, 04:57:56 PM »
the spondon calipers used the same seals and pistons as the ap calipers so no problems there , the ap adjustable ratio master cylinder is just a standard master with a crude slider that alters the leverage they dont work any better or worse than normal one . the leavers used to cost a fortune though . master cylinder ratios were understood perfectly well in the 70´s my rg500 came with 3 size options depending on use .
I have an adjustable ratio AP front master and it certainly doen't look like that. had it for year after a trade for some work. I should throw it on the CB with the DOHC calipers I have.
Offline slikwilli420
  • Master of Disaster
« Reply #102 on: August 17, 2018, 07:19:34 PM »
Still lots more research to be done on calipers. If I go with the AP instead that's still going to be a killer setup that I would be thrilled with.
Bearing adapters all done except a quick smoothing of the sides where the water jet left it's mark them off to vapor blast.
« Reply #103 on: August 17, 2018, 07:36:37 PM »
What about the pads?
« Reply #104 on: August 17, 2018, 08:12:48 PM »
Not 100% sure but I believe all those period calipers from AP, Grimeca, Spondon, and Scarab all use the same pad. I need to confirm though before going with the spondon ones.
« Reply #105 on: August 17, 2018, 09:31:39 PM »
If the pistons are the same, and the pads are the same, all those calipers should perform the same. Not as well as a twin piston caliper from 1982, I'd wager. ;) Still in the "period" for your class. How much do the calipers cost? I picked up two 32mm calipers with brackets from a breaker in Phoenix for $87, plus the 180 mile round trip. One is now on the Seeley, and the other is on the "ditch pump" FT500. ;D
« Reply #106 on: August 18, 2018, 05:50:09 AM »
These calipers were in use well into the 80's so I'd imagine they are superior to a factory 2 piston caliper. They range in price from about $150-300 depending on brand.
Offline simon#42
  • liverpool
« Reply #107 on: August 18, 2018, 06:37:25 AM »
ok have had a look at a few calipers  and will post some pictures , weights , piston sizes and pad friction area ,  hope this helps
first though some details about adjustable master cylinders , two pictures are of a standard period master the rest are of an adjustable ratio master , you should be able to see that when you adjust the screw in the leaver it alters the position it presses on the slider , this increases or decreases the leverage ratio . pretty crude but it does give you some adjustment
Offline simon#42
  • liverpool
« Reply #108 on: August 18, 2018, 06:39:14 AM »
Offline simon#42
  • liverpool
« Reply #109 on: August 18, 2018, 06:41:06 AM »
Offline simon#42
  • liverpool
« Reply #110 on: August 18, 2018, 06:44:33 AM »
the monoblock spondons
Offline simon#42
  • liverpool
« Reply #111 on: August 18, 2018, 06:45:17 AM »
more
Offline simon#42
  • liverpool
« Reply #112 on: August 18, 2018, 06:46:43 AM »
two sizes of brembo
Offline simon#42
  • liverpool
« Reply #113 on: August 18, 2018, 06:49:26 AM »
lockheed 2 piston calipers
Offline simon#42
  • liverpool
« Reply #114 on: August 18, 2018, 06:53:57 AM »
and finally some slightly later 4 piston sponden and lockheed , i have included these to show that spondon were so pleased with there monoblock calipers they dumped the idea when they went to 4 piston , also some spondon caliper mounts that i think mat was talking about
Offline simon#42
  • liverpool
« Reply #115 on: August 18, 2018, 07:05:01 AM »
ok weights ,
all have no pads fitted and all have alloy pistons
lockheed  1lb 11oz
spondon   1lb 9oz
large brembo  1lb 13oz
smal brembo  1lb
4 piston lockheed  1lb 8oz
4 piston spondon  1lb 9 oz
piston sizes
spondon / ap  40mm
large brembo  38mm
small brembo 32mm
pad size
spondon / ap  57mm x 38mm
large brembo  55mm x 38mm
small brembo  38mm x 35mm
all measurements done quickly and are approximate  !!
« Reply #116 on: August 18, 2018, 09:56:55 PM »
Imagine in one hand and #$%* in the other and see which fills up first. ;) ;) The Honda two piston calipers work very well; I first started investigating them when I noticed how much better the front brake on the ditch pump was than a single 750 caliper, despite the same 295mm rotor and 14mm master diameters.
An opposed piston caliper has no hydraulic advantage over a single piston caliper. The chart from Vintage Brakes is confusing, because they double the ratio for opposed pistons, but in reality, they recommend the same size MC for a single piston caliper and a two piston opposed caliper of the same diameter. It took me a while to get my head wrapped around that. ;D
The 32mm twin piston caliper is roughly the same as a 45mm caliper, hydraulically speaking.
The advantage to opposed piston calipers is less drag, as each piston retracts from the rotor, instead of only on one side: twice the clearance.
The pads are about 89mm x 29mm, minus the corners; I would estimate the surface area to be about 2460mm sq. Most of this area is near the OD of the rotor, where it's most effective.
Offline simon#42
  • liverpool
« Reply #117 on: August 19, 2018, 04:05:20 AM »
pad area is important but pad compound has a very big effect , is there a range of racing compounds for these calipers ?  . the good thing about using a racing caliper is the pads are always available in the correct compound . i would use two of the small brembos with 260mm discs on a 250 and with a soft racing compound pad be able to lift the rear wheel entering every corner . the pads would  last around 100 miles
« Reply #118 on: August 19, 2018, 11:54:58 AM »
I use the small Brembo's with race pads too. Mind you on a heavier bike than a 250, but they're lightweight and plenty adequate. Build them with good brakes in mind, then use them sparingly on the track.  ;D
I like to "dress" the discs with a rotor flex hone every few races.
Offline bear
  • Leeton in Australia
« Reply #119 on: August 19, 2018, 03:56:03 PM »
I too use the Bremdo's. We use the larger 08's on the sidecar in conjunction with ion disks mounted on a floating carrier.
We settled on this setup after mix and matching many different combinations over a lot of years.
« Reply #120 on: August 13, 2019, 06:55:51 AM »
Wow, time flies when you have a bunch of bikes to work on and not enough time or money! Well, I sold my '09 Thruxton so one of the those problems is partially alleviated, at least short term, which means Im back to this one.
Chris at motogpwerks was gracious enough to sell me his last swingarm and the only 4-2-1 exhaust he had. I now have some sweet Calfab and MGPW pieces to add to the bike.
Arm, will be getting a custom pivot bolt, hollow axle and aluminum chain adjusters:
Didnt unpack the exhaust all the way, but here is the end can:
Bike as it sits:
The AHM trees from Chris are absolute jewelry and fit my goals nicely. They only need steering stops to be ready to rock. My front forks are still in pieces but will be going back together soon. The tank is a pickup from Mid Ohio this year for like $50 and the seat was bought last year.
I was really struggling to make adapters for the rear wheel for brakes and sprockets, and happened on a set of 18" GSXR wheels that will be going on their place, at least for now. ISR has ceased all communication on my custom rotors and I have not heard from them in a few months now. It really sucks to be out $350 but what can really be done with an international company that I paid via bank transfer? Either way, I can get ZX7 Kawi rotors for the GSXR wheels, 310mm and readily available. They won't look the part quite as well as the Astralites and custom rotors on vintage carriers, but that can be remedied later.
I should be getting my Ohlins piggyback shocks back from rebuild soon and then I can get a roller together. This is still a long, long, long term project but I am trying to make progress on all my bikes a little at a time.
« Reply #121 on: August 13, 2019, 01:41:45 PM »
Sounds really good matt...love that seat,and want one for my orange f.  Was it a used part find or what?
« Reply #122 on: August 13, 2019, 04:34:46 PM »
Thanks Sean! Seat was a grab from a bike getting parted on the forum here last year. Seat cover job isn't great but it'll work for now and has the shape I wanted.
« Reply #123 on: August 13, 2019, 04:48:50 PM »
 Are you running  20mm rear axle ? I can sell some chain adjuster sideplates  if you wantvto make the middle parts. Like this.. if I can finish.. how thick is the swingarm ends?
« Reply #124 on: August 13, 2019, 05:18:10 PM »
20mm front and rear. I'll need to check once I get the swing arm ready to put on. The adjusters it came with are steel which I won't be using.
