Author Topic: Custom Tree Offset Recs.  (Read 1162 times)
Offline dunc
« on: July 15, 2018, 02:52:40 pm »
Hello All.
I'm looking to make my own triple trees / stem for primarily weight and aesthetic reasons.
And while I'm at it - curious if there's any recommendable offset changes I should make.
To note - bike has 18 inch front and rear, stock conventional forks with racetech gold valves, ikon rear suspension on a 77K swing arm.
Stock offset is probably fine - but was curious what all of you have for input. And if there's some triples I should reference for aesthetics, not planning on a simple water jet job.
Dunc
it's amateur hour somewhere.
Offline slikwilli420
  • Master of Disaster
Re: Custom Tree Offset Recs.
« Reply #1 on: July 15, 2018, 03:02:11 pm »
Check trail and shoot for about 95mm as the bike sits.
Offline dunc
« Reply #2 on: July 15, 2018, 03:18:30 pm »
Was hoping you'd chime - referencing a lot of your build.
Is 95mm the sweet spot you've found?
« Reply #3 on: July 15, 2018, 03:42:48 pm »
It's what I'm running and what many more modern sport bikes run. It's considered a close to perfect number.
Offline dunc
« Reply #4 on: July 15, 2018, 03:44:31 pm »
Close to perfect sounds good enough!
Bike will be a roller in the next few weeks. Will be able to take measurements then and get to CAD.
« Reply #5 on: July 15, 2018, 06:53:11 pm »
Cadamnit, doesn't anyone handcrank anymore ?
 Rough em out with waterjet..  how thick are you going ?
