Poll
Middleweight Streetfight
Oette's Hybrid 550/650 Blue Falcon
34 (47.9%)
HondaAddict's 1975 CB550K Restoration
37 (52.1%)
Total Members Voted: 68
Voting closed: July 31, 2018, 10:47:20 PM
Author Topic: Vote for Bike of the Month August 2018  (Read 6014 times)
  • Moderator
« on: July 15, 2018, 10:47:20 PM »
Oette’s Hybrid 550/650 Blue Falcon
http://forums.sohc4.net/index.php/topic,171794.0.html
HondaAddict's 1975 550K Restoration
forums.sohc4.net/index.php/topic,152139.0.html
« Last Edit: July 16, 2018, 10:14:20 AM by SOHC4 Cafe Racer Fan »
  • Moderator
Re: Vote for Bike of the Month August 2018
« Reply #1 on: July 18, 2018, 08:43:59 AM »
Oette and HondaAddict,
Feel free to post a brief summary of your builds -- what you started with, what your goad was, what work you did, any specialty parts/work, help you received, etc.  People like to hear the story.
I started following Oette's build some time in 2013.
He started with a 1978 CB550K and has done what I would describe as 3 rebuilds:
The prior 2 Green Hornet rebuilds of the bike are documented on a second, more extensive thread: http://forums.sohc4.net/index.php/topic,86356.0.html
From 2012-2013, Oette did a complete frame off build and rebuilt his 550 engine (Rebuild 1)
In 2014, Oette became one of the earlier adopters of the  650 engine swap club, but he did it with an added degree of complexity.  He kept the 550 (kickstart) bottom end and mated it with a 650 top end.  He also did his own porting.  (Rebuild 2)
YouTube
Vimeo
Not a valid vimeo URL
This last version was more than a bodywork (tank, seat) and color change, and included a modern fork swap.  (Rebuild 3)
Offline HondaAddict
    • Videos on my CB550K restoration and other projects
« Reply #2 on: July 18, 2018, 05:49:35 PM »
Thanks, SOHC4 Cafe Racer Fan, for posting the photos of my '75 CB550K. Here's a bit about me and the saga of this project. Apologies for the long post.
I've been riding motorcycles since I bought a new YZ80 in 1978. I've had dozens of bikes over the years, some of which I bought damaged after accidents ('82 750 Nighthawk) or in boxes ('77 GT750). I like mechanical things (heck, I'm a mechanical engineer) and have rebuilt more old vehicles and machines than I can remember. I did this out of necessity when I was young, and as a hobby now that I'm north of 50. Pictured below are a couple of my past projects and one for the future.
I had never done a frame-off motorcycle restoration and I've always loved the 70's CB/Fours. I have a well-equipped shop and was in need of a project, so I started looking for a worthy CB. It took 6 months to find this one (these photos from the kijiji ad):
I bought it in 2015 from a guy who was planning to fix it up but had too many projects. He had bought it from the original owner, who stopped using it in 1981 and stored it for 34 years in a spare bedroom of his house. It had ~15,700 miles, its MVI sticker expired in June of 1976 and it was last licensed in 1981. The original tool kit and owner's manual were included.
It came to me with a very clean 77/78 550K OEM exhaust system. The PO planned to use it because the original pipes were shot. It bolted on, but interfered with the rear brake lever, kick starter and side stand, so I sold it and bought a Delkevic 4-into-1 system.
The general appearance of the bike was decent for its age, but under the surface were all the signs of a 34-year sleep. The carbs were a mess. The front brake and clutch were stuck, although the engine rolled over on the kickstarter. O-rings and seals were hard, electrical connections were corroded and there was plenty of rust, especially inside the fuel tank.
My first chore was to get it running and rolling to see if it was a worthy backbone for a project. I changed the oil/filter, got the carbs into passable condition, unstuck the clutch/brake, adjusted the points and fixed a variety of electrical issues. I geared up a temporary gas supply and it started quite easily. The video below shows it was smoking, but I figured rings were stuck and there's no smoke now.
I drove it a couple of miles and ran it through the gears - all was good. I did a compression test on the warm engine, then posted the numbers here for opinions and apparently they're acceptable at 128-132 psi. Aside from the valve cover and rockers, I didn't touch the engine internals. It ran well, had fairly low miles, no leaks, good compression, and the camshaft looked fine, so I figured it was better left alone.
Thanks to other priorities, I didn't do much on this project from October 2015 to September 2017. I did most of the work between last September and June. Here's what I repaired/replaced:
Repairs
  • Overhauled carb and rack assembly
  • De-rusted gas tank
  • Rebuilt master cylinder
  • Unstuck and cleaned clutch
  • Disassembled, de-rusted and polished wheels (rear rim is a new one that came with the
    bike)
  • De-rusted and undercoated fenders
  • De-rusted taillight, fork ears, turn signals, rear shocks, grab bar and other chrome pieces
  • Replaced seals and o-rings
  • Replaced valve cover and rockers. As everyone here knows, the older 550 valve covers had a design flaw that caused excessive wear in the rocker shaft bores.
  • Cleaned and repaired wiring harnesses
  • Sanded, primed, painted and clear coated 100+ parts, brackets, bolts, etc.
  • Sanded/polished engine covers, fork cases and ~20 other aluminum parts
  • Disassembled, primed and painted seat pan
  • Disassembled handlebar controls and painted housings
  • Removed, cleaned, sanded and painted the engine
  • Cleaned, sanded, primed and painted the frame
  • Touched up paint on emblems
New Parts
  • OEM carb rebuild kits and jets
  • Petcock rebuild kit
  • Brake caliper kit
  • Master cylinder rebuild kit
  • Braided steel brake lines
  • Brake shoes/pads
  • Gaskets, o-rings and seals
  • Gauge covers
  • Spark plugs/caps
  • Stainless steel engine and carb bolts
  • LED instrument bulbs
  • Ignition points
  • Drive chain and sprockets
  • Delkevic 4-into-1 exhaust
  • Tires/tubes
  • Air filter
  • Ignition switch
  • Battery
  • Flasher relay
  • Sealed beam headlight
  • Fork cap bolts
  • Warning decals
  • OEM hand grips
Used Parts
  • Handlebars
  • Valve cover
  • Starter cover
  • Mirrors
  • Headlight bucket
  • Horn
  • Turn signal housings (2)
This project tested my determination more than any other to date. I was getting pretty frustrated towards the end - it seemed like there was another unexpected (often costly) challenge every day for a few weeks. It has reminded me that when a project is fighting me (and this one fought like a champ), it's best to take some time off and the problems will be much easier to solve when I come back with a fresh perspective. That's why it looked like this for about a week:
It's road legal now and I've put in about 100 miles shaking it down. I still have a few minor issues to solve, but this old bike is really working well. As the tach climbs above 6k, it pulls like hell and sounds divine. Below is a video of it running.
I believe the late 60's/70's CB series played no small part in building Honda's brand for innovation, performance and reliability. And to my eyes, they're as pretty as a motorcycle could be. I'm proud to have this sample of Soichiro-san's work.
During this project, I searched SOHC4.net hundreds of times. It is THE source for information on these bikes. You guys have never let me down - thanks! I hope to start another project thread here someday. I crave a 75-77 CB400F.
As for the nomination, it's an honor to be in such good company. Oette's Blue Falcon is a beauty - clearly the product of impressive skills and a great eye for design. Well done, Oette!
« Last Edit: July 21, 2018, 11:20:21 AM by HondaAddict »
1976 Honda CB400F
1975 Honda CB550K (sold in 2020)  Project thread | Videos
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1984 Honda V65 Sabre (sold in 2020) Project thread on V4Musclebike.com | Video
1986 Honda Z50R
« Reply #3 on: July 18, 2018, 06:51:48 PM »
Dang!  I did not realize that was original paint when I nominated your bike.  Kudos for that!
  • Moderator
« Reply #4 on: July 19, 2018, 08:46:50 AM »
My first chore was to get it running and rolling to see if it was a worthy backbone for a project. I changed the oil/filter, got the carbs into passable condition, unstuck the clutch/brake, adjusted the points and fixed a variety of electrical issues. I geared up a temporary gas supply and it started quite easily. The video linked below shows it was smoking, but I figured rings were stuck and there's no smoke now.
https://youtu.be/UnO9k4xZjY0
Repairs
    bike)
New Parts
  • Brake caliper kit
  • Brake shoes/pads
  • Gauge covers
  • Spark plugs/caps
  • Ignition points
  • Tires/tubes
  • Air filter
  • Ignition switch
  • Battery
  • Flasher relay
  • Fork cap bolts
  • Warning decals
  • OEM hand grips
Used Parts
  • Handlebars
  • Valve cover
  • Starter cover
  • Mirrors
  • Headlight bucket
  • Horn
It's road legal now and I've put in about 100 miles shaking it down. I still have a few minor issues to solve, but this old bike is really working well. As the tach climbs above 6k, it pulls like hell and sounds divine. Linked below is a video of it running.
https://youtu.be/Ypn1Y8EG2ks
Note to nominees,
This is the BEST BOTM summary I have EVER seen posted.  Wow.
Like Sean, I had not noticed that the original paint had been preserved and restored to its glory days.  What a great bike.
Offline HondaAddict
« Reply #5 on: July 19, 2018, 02:08:02 PM »
Note to nominees,
Thanks! I was worried the post was getting long, so I'm happy to hear it's OK.
Thanks! I didn't mention the orange paint in my thread, but it was in decent shape overall. It has some scratches and blemishes, but I simply didn't have the budget to get it repainted to original specs. After washing the tank & side covers, I gave them a good once-over with rubbing compound and then a coat of Mothers carnauba cleaner/wax. Although it's still got most of the blemishes, a good buffing brought out a pretty decent shine. Like most tasks on this project, I did all of this after spending a few hours on these forums researching my options.
« Last Edit: July 19, 2018, 02:28:00 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
  • Moderator
« Reply #6 on: July 20, 2018, 04:02:26 PM »
Five days into voting and the bikes are only 1 vote apart.  Close racing!  Don't forget to cast your vote.
« Reply #7 on: July 20, 2018, 04:15:42 PM »
Two great bikes...
Offline dbenton
« Reply #8 on: July 21, 2018, 06:21:40 AM »
Great bikes, really nice work.
  • Moderator
« Reply #9 on: July 24, 2018, 08:54:06 AM »
The race could not be closer -- dead even so far.  Remember to vote if you haven't already done so.
« Reply #10 on: July 24, 2018, 09:36:39 AM »
I had an idea that this one would be tight Don but not this tight, hahahaha.
  • Moderator
« Reply #11 on: July 27, 2018, 02:19:11 PM »
Three days later and it's a dead heat again!!
« Reply #12 on: July 27, 2018, 03:36:44 PM »
And 1 hour later it's not, haha. Never seen one this close.
  • Moderator
« Reply #13 on: July 30, 2018, 08:21:53 AM »
Down to the wire. Only a day and change to vote!
« Reply #14 on: July 30, 2018, 11:42:26 AM »
I have a nice one lined up for next month Don but need to find the guys user name so I can contact him.
Offline HondaAddict
« Reply #15 on: July 30, 2018, 02:20:02 PM »
Here are a few close-up shots of my bike. I hadn't included any of these in my summary above and I have ~2,900 photos of this project, so I figured I should post some of them someplace. :)
« Last Edit: July 30, 2018, 02:29:58 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #16 on: July 30, 2018, 02:44:31 PM »
You left that a bit late, hahaha.
Offline Drew_ATL
  • What’s a Torque Wrench?
« Reply #17 on: July 30, 2018, 04:59:11 PM »
total inspiration- hard to pick!
I blame Bill, he made me love these bikes! :)
...respectfully watching and learning.
Offline HondaAddict
« Reply #18 on: July 30, 2018, 06:45:28 PM »
Haha. Guilty as charged. Part of the problem with having thousands of photos is finding the time to sift through them. I've been travelling for work quite a bit lately and internet is spotty at best in some countries. It can be quite a chore to upload photos on a connection that seems slower than dial-up. :)
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #19 on: July 31, 2018, 12:36:52 AM »
Dead level again with just hours to go, get your votes in guys.
  • Moderator
« Reply #20 on: July 31, 2018, 10:01:22 AM »
This is a very close race. Only a 1 vote separation, so your VOTE counts.  Get them in.
« Reply #21 on: July 31, 2018, 10:41:58 AM »
And a half hour later it's dead level again, hahaha.
Never ever seen one this close.
Offline calj737
  • I refuse...
« Reply #22 on: July 31, 2018, 11:24:52 AM »
Shame neither has black rims because we all know who’s vote that bike would get  ;D ;)
« Reply #23 on: July 31, 2018, 11:55:01 AM »
I've just told Don who I voted for Cal, which one was it though ? hahaha.
And it's still dead level, haha.
  • Moderator
« Reply #24 on: July 31, 2018, 07:51:47 PM »
Only a few hours left and only 1 vote separating the two.
