Author Topic: Carbtune readings.  (Read 1800 times)
John
Carbtune readings.
« on: June 05, 2005, 08:11:59 PM »
Hey, first, thanks to everyone who helped me with my clutch issues.That is sorted here is problem #2. When balancing carbs with the carbtune, I adjust all four carbs to read almost perfectly in sync. Then i blip the throttle, wait for things to settle down and the relationships between cylinders change. Sometimes slightly, most times enough to where i need to readjust. This also happens if i hit the kill switch and restart. If it weren't for the fact that my engine would become a puddle of aluminum on the garage floor, I feel like i could sit around doing this all day getting slightly different readings each time. What am i doing wrong? The bike is a 71 cb750 which otherwise idles and runs good.Carbtune is assembled per instructions and appears to otherwise work great. Any thoughts?
Thanks,
john
Offline oldbiker
  • I HATE RAIN
Re: Carbtune readings.
« Reply #1 on: June 06, 2005, 01:35:02 AM »
This sounds as though the carbs are not returning to the closed position after you have blipped the throttle. Could be something as simple as sticky cables or a tiny bit of grit in the throttle mechanism, or even the return spring being a bit tired.
« Reply #2 on: June 06, 2005, 04:28:54 AM »
Check for vacuum leaks at the intake boots. Spray some brake cleaner around the boots while it is running- if the idle changes you have leaks. Personally I'd replace the boots anyway secondary to age. Valves out of adjustment will also cause what you describe.
« Last Edit: June 06, 2005, 04:32:40 AM by MRieck »
kaysystems
« Reply #3 on: June 06, 2005, 09:23:18 AM »
Are you sure that the carbtune is absolutely vertical. If not the sliders may stick a little in the tubes.
David
