Author Topic: cam choice  (Read 2230 times)
Offline Tintop48
cam choice
« on: July 16, 2018, 10:22:26 PM »
hi,i have a 77 A and decided to put an 836 kit on,which has 10.5 to 1 compression.im doing this to hopefully increase torque in the low to mid rpms,reason being thats where i like to ride.this bike will never see over 5000rpm. my question is that right now im using the 750 k cam and roundtops,would i enhance the low to mid with that cam or should i use the A cam?any help would be appreciated.
Offline garyS-NJ
Re: cam choice
« Reply #1 on: July 17, 2018, 01:56:48 AM »
I don't know much about caming a Honda and I'm sure others will chime in with the go to cam for the 836 kit but why not ask the supplier? And cam choice will be dictated somewhat by your head work and intake and exhaust... I still think the stock intake and exhaust is overly restrictive
Sent from my VS987 using Tapatalk
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
Offline dave the welder
  • dave the welder
Re: cam choice
« Reply #2 on: July 20, 2018, 06:41:28 PM »
do NOT use stock A cam.it has LESS lift and duration.keep the k cam
don't buy it build it
Re: cam choice
« Reply #3 on: July 20, 2018, 07:20:19 PM »
that's silly...unless all you want to do is putt putt and then why bother with a cam change at all.  5000rpm is just about where the torque curve starts
Offline slikwilli420
  • Master of Disaster
Re: cam choice
« Reply #4 on: July 20, 2018, 08:16:24 PM »
This makes no sense. These bikes are not designed to run at that rpm. You will get poor performance and likely carbon buildup on the valves. Better torque just gets you up to speed faster. Shift at 8 grand as designed and enjoy the bike as it was meant to be. If you like short shifting and being in 4th gear at 30mph, get a Harley.
Re: cam choice
« Reply #5 on: July 20, 2018, 08:53:10 PM »
Careful matt, we talking about the Honda powerglide aka automatic
  • Moderator
Re: cam choice
« Reply #6 on: July 21, 2018, 02:03:09 AM »
hahaha, they only have 2 gears mate and this is the best cam by far for what this guy wants and his piston set up. It's available from Dynoman.  http://www.dynoman.net/images/engine/cams/DP/DP295Cam.jpg
Offline garyS-NJ
Re: cam choice
« Reply #7 on: July 21, 2018, 07:26:27 AM »
Shift at 8 grand?  I have a dohc 1995 katana 750 and I think I shift that bike around 8k when I'm hot dogging.  I don't remember shifting my '78 cb750F that high.  And yes, I also missed the  original post 750A is automatic and he was asking about a 750A stock cam or a 750K stock cam...
78 CB750F3
Offline garyS-NJ
Re: cam choice
« Reply #8 on: July 21, 2018, 07:35:45 AM »
Hmmm, a street and race cam in a hondamatic with an 836 kit and 10:1 compression. It all sounds oxymoronic especially after recently working on a hondamatic 400 (I didn't ride it but it seemed pretty tame in the garage).    So the K cam has more lift but the stock head set up for an A will accept the added lift?  As well as the recommended dynoman cam?  What about a cam from an F bike?
78 CB750F3
Re: cam choice
« Reply #9 on: July 21, 2018, 08:00:13 AM »
Brain farted on the auto thing. Still ride it harder than you are and it will treat you right.
Then you aren't riding it right. These are meant to be ridden like the sport bike they were. I raced a stock '76 F engine last year, shifting at 9500 all season, and it never went boom.
Offline garyS-NJ
Re: cam choice
« Reply #10 on: July 21, 2018, 08:10:11 AM »
My 78F has been laid up for a few years now so I guess my memory is fuzzy.  But if all goes well I'll have a 79 gs1000 on the road today and we will see if she shifts at 9500 (hard to believe because I just looked at the tach and red line is 8500).
78 CB750F3
Re: cam choice
« Reply #11 on: July 21, 2018, 09:03:48 AM »
Not sure why a roller bearing crank dohc 1000 is relevant here?
  • dave the welder
Re: cam choice
« Reply #12 on: July 21, 2018, 09:21:25 AM »
read somewhere use a k cam and pick up  a cam gear you can advance that will help low end and mid range
Offline underdog
Re: cam choice
« Reply #13 on: July 21, 2018, 11:15:32 AM »
  Sam was dead on, you'll be happiest with that cam and maybe 4 degrees of advance. I have a CycleX CX-3 and I like it, but the 295 is better. The adjustable cam sprocket is definitely worth the $40.
