Author Topic: Hello from Toronto, Canada  (Read 1082 times)
Offline Barneycanoe
« on: July 20, 2018, 11:49:31 AM »
Hello all, I have a 1979 CB650 which, not coincidentally, was my first bike as a skinny 20-year-old. This particular bike I purchased in 2011, fixed up a few things, painted the tank, and sold to a young couple. It had about 9000 miles on it. A friend had made me a new leather seat for it.
Browsing Kijiji one day, I did a double-take when I recognized that old bike and the seat, now being sold for parts. I went and took a look and it was in sorry shape. Had been left outside by the looks of it for the past seven years. Apart from four broken turn signals it seemed complete and nothing was bent where it shouldn't have been. It had no ownership or keys. Got it for $360.00 Imagine my surprise when I obtained the used vehicle information package and found it was still registered in my name!
I've always worked on my own bikes. This site has been a huge help in assisting me with the peculiarities of the 650s.
So far I've
-Replaced the ignition
-Replaced front master cylinder and caliper
-replaced both tires
-replaced sprockets and chain
-replaced the turn signals
-new fork oil
-oil change and filter
-cleaned the tank
-cleaned the carbs (without pulling the slow jets) They were not in terrible shape
-disassembled the speedo and tach to straighten the needles during which I broke the tach needle :(
-vacuum-synched the carbs
-adjusted the valves
-checked the timing
-checked the coils and that all plugs are getting a park
-adjusted the floats (only 1, actually)
So here are my issues:
Minor- two-wire aftermarket rear turn signals  are turning on with ignition. Everything wired correctly so not sure how this is happening. Only the three-wire fronts are supposed to be running lights.
Major- Cylinders number three and four are not heating up the pipes. Plugs on one and two are textbook tan. Three is a bit better than four's plug which has a bit of black easily wiped-off carbon but doesn't really look used. This was the carb than needed the float adjusted as it was filling too high. I also have a stumbling around 6,500-7000k rpm now and it won't rev higher. Somewhere along the way I had it revving strongly to 8,000 so I'm not sure where I went backwards. I do have a new air filter on order but the old, probably original one doesn't look terrible.
Three's pipe gets hotter than four but not as hot as 1 and 2. Occasionally there has been a bit of white smoke out of the right side muffler.
11,000 miles seems a bit newish for ring problems. At this point all I can think of is to re-check the valves but I did them very carefully with my wife checking things as I went along.
Any suggestions would be welcomed.
Dave, Toronto, Canada
Offline Barneycanoe
Re: Hello from Toronto, Canada
« Reply #1 on: July 20, 2018, 11:51:38 AM »
ps, I am getting some popping from the right hand pipe on deceleration
Dave
Offline Robbo
« Reply #2 on: July 20, 2018, 04:14:36 PM »
Dave, are you getting spark on 3 and 4?
Have you done a compression check on all 4 cylinders?
And welcome.  Amazing that the ownership never got transferred out of your name....and that the bike came back to you.  What part of the city are you located?
1973 CB350 Four, 1975 CB550K
« Reply #3 on: July 20, 2018, 04:18:28 PM »
Welcome from Texas.   Just watched the Toronto Indycar race, pretty exciting, did you happen to go?
Popping when decel can be a lean cond in the carbs or an exhaust leak.   If you need further help with this, post a new thread in the tech section, it will get more views over there.
Good luck...
Offline Barneycanoe
« Reply #4 on: July 24, 2018, 07:40:53 AM »
Robbo, hello, I am getting spark on 3 and 4. Will get a compression tester from Canadian Tire to test compression. Hope that's not it but I've tried pretty much everything else. Bike does run on all four, as when I pull the plug boots at idle it kills the engine (any of the four).
I am actually near Stouffville.
Stev-o, I didn't go down to the race, rarely go into Toronto these days due to the traffic. I will  post part of this message in the tech forums, thanks.
Dave
Offline Barneycanoe
« Reply #5 on: June 07, 2019, 08:12:50 AM »
Just to let you all know, after the third time pulling the carbs I got it all sorted. Now it's running fantastic. Just have to work on the cosmetic issues. I am having the tank painted professionally too.
Dave
Offline ltenk
« Reply #6 on: June 08, 2019, 11:29:49 AM »
Hey Dave, where are you getting the tank painted? I’m in the GTA and will need to be doing the same...
Offline jamesw
« Reply #7 on: June 22, 2019, 06:36:07 AM »
Here's who I use, and will continue to use for any future projects. He's north of the 401 in Scarborough.
http://www.connerycustompaint.com/
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline Robbo
« Reply #8 on: June 22, 2019, 11:48:06 AM »
James did you get the tank painted that is pictured in your avatar?  Approx. how much did it cost you if you don’t mind me asking?  I’m on the other side of town.
Cheers, Robbo
Offline ltenk
« Reply #9 on: July 12, 2019, 05:04:56 AM »
Thanks, James!
