Author Topic: Wiring question  (Read 799 times)
Offline sdefoor
Wiring question
« on: July 23, 2018, 01:53:38 PM »
I have 5 wires coming from the alternator area. But what does the long white wire connect to?
I know 3 yellow to 3 yellow, white plug to white plug, blue to oil pressure unit. But the other one confuses me.
Cb750 K3
Offline calj737
  • I refuse...
Re: Wiring question
« Reply #1 on: July 23, 2018, 04:50:07 PM »
Looks like it has been substituted for RED. Connects to battery POS.
Offline chrisbc55
Re: Wiring question
« Reply #2 on: July 23, 2018, 10:51:48 PM »
Neutral switch sensor wire
Offline calj737
  • I refuse...
Re: Wiring question
« Reply #3 on: July 24, 2018, 02:32:34 AM »
I doubt that given that the wire is extra long, appears to be a much larger gauge, and has a ring terminal installed. The NEU is Gr/Red striped and would have a bullet connector to plug into the harness. The RED connects to the solenoid post or the battery.
Offline disco
Re: Wiring question
« Reply #4 on: July 24, 2018, 03:35:38 AM »
It’s the neutral switch alright. It’s got one of those woven covers on it.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Wiring question
« Reply #5 on: July 24, 2018, 04:05:17 AM »
Neutral switch wire. The sheath hides the true color of the wire inside and is used to protect the wire since much of it is exposed in the sprocket well and beneath the engine (similar to the ignition wires where they exit behind the points cover). It routes behind the shift cover to the underside of the engine below the sprocket to the neutral switch on the bottom of the motor. This is the sub harness between the alternator and the main harness. In stock trim there was a tin tab under one of the engine bolts behind the shift cover (under the sprocket cover) and a tin tab on one of the oil pan bolts that fold over to hold this wire out of harms way.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline sdefoor
Re: Wiring question
« Reply #6 on: July 24, 2018, 10:07:32 AM »
Thanks guys. Covering confused me so I pulled it back and looked at the wiring color and it looks as if it definitely is the neutral switch wire.
