Author Topic: 400/4 Jumping out of gear  (Read 739 times)
Offline Davelu88
« on: July 26, 2018, 11:22:06 AM »
400/4 jumping out of 1st gear back into neutral, don't do it in other gears, I have adjusted clutch  by the manual to the best of my ability which isn't much!! but no joy, any help greatly appreciated.
Offline Bodi
Re: 400/4 Jumping out of gear
« Reply #1 on: July 26, 2018, 01:16:16 PM »
Likely a shift mechanism problem. they should not jump out of gear. The external mechanism - selector drum head and the shifter levers - is accessible under the side cover. The drum detent should be very secure, its spring can get weak and allow it to turn under force from the internal parts.
Rather more likely is damage/wear on the shift drum and/or shifter forks. This is all inside the main case and the bottom has to be removed to get at it. Complete transmissions show up on ebay fairly often, not too much $$$, just a gamble "is this better than what I have". NOS parts are not common and are expensive. All the transmission parts are NLA from Honda except some of the bearings.
Offline Davelu88
« Reply #2 on: July 26, 2018, 01:44:09 PM »
Many Thanks
