Author Topic: '71 Handlebar Switch Rebuild  (Read 549 times)
Offline Lupo_00
« on: July 27, 2018, 01:57:52 PM »
Hey guys,
I have Hondaman's book and was looking at rebuilding the right handlebar switch.  The grounding locating post is flat out missing.  Wondering if anyone has run into this and what you did to fix it.
Thanks!
Offline dusterdude
Re: '71 Handlebar Switch Rebuild
« Reply #1 on: July 27, 2018, 04:45:36 PM »
Is that the little post that goes into the handlebar?
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline pjlogue
« Reply #2 on: July 27, 2018, 05:43:37 PM »
You can use an M5 screw or bolt.  Cut the head off, thread the hole in the handlebars.  Trim it to a length so it just screws into the bars enough to go through the wall but doesn't protrude into the bars where it will mess up the wiring.  and screw it in using some locktight  (round off the end of the bolt)  You might need to drill out the receiving hole in the control a little.
I did this on mine when I replaced the controls which didn't have the studs.  Worked great.
-P.
Offline Lupo_00
« Reply #3 on: July 30, 2018, 08:48:52 AM »
-P.
This worked out great. Thanks a lot man!
