Author Topic: *1' Honda cb900c broken Carburetor float pin Mount  (Read 1316 times)
Offline Boots_81_cb900c
« on: August 01, 2018, 08:56:37 PM »
So the other day i was trying to remove the Float pin from my #4 carb on my 81' Honda cb900c, when i began to tap the pin out (after i sprayed PB blaster on it and let it sit) the Pin mount broke in half. What is the best way to go about fixing this issue? or where could i send it to get it micro welded back on? and lastly, does anyone have an extra #4 carb laying around that they would let me take off there hands?
Re: *1' Honda cb900c broken Carburetor float pin Mount
« Reply #1 on: August 01, 2018, 09:24:51 PM »
Here is a Pic of the mount
« Reply #2 on: August 01, 2018, 09:26:23 PM »
 This is our resident micro welder on the forum ---  http://forums.sohc4.net/index.php/topic,18649.0.html
« Reply #3 on: August 02, 2018, 09:11:48 PM »
 Mine broke at the pin hole. I used a brass bullet case over the pin with some JB weld. Then redrilled the hole out and last I knew it was working fine.
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: August 02, 2018, 09:58:12 PM »
I'll vouch for Jim French's work.  Top notch and reasonable...Larry
« Reply #5 on: August 03, 2018, 04:03:48 AM »
I emailed Jim and spoke with him on the phone!! Sending the carb to him at the beginning of next week.
 I appreciate the Help gentlemen.
Ill Post the finished product when i get it back from him.
« Reply #6 on: August 18, 2018, 08:17:04 PM »
 Good choice.
