Hello forum!
I bought and installed a new wire harness on my 72 cb500. Many of the old wires are refitted and worked on over the years, with seemingly random colours, so sometimes I've had to guess and to try and fail on what cables connect to what on the new harness. Now everything seems to work but the back light. I've also removed the turn signals, so I have a couple of left over connections...
So my questions are:
1. What is "front stop switch" in the wiring diagram? I always assumed it was the engine killer switch, but it doesn't fit with the wiring, so now I'm confused...
2. I have a switch that switches on and off the light (back and headlights), but it doesn't seem original. Is this my front stop switch?
3. Also there is a loose black cable that comes out of the harness, by the ignition with the cables going to the coils (A "her"/negative connection..). It doesn't seem to fit anywhere. Do anyone know what wire this is?
Thank you!
