Author Topic: What kind of plastic are CB750 side covers made from?  (Read 2345 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 08, 2018, 03:12:54 PM »
Looking to replace a tab and am wondering about which epoxy to try.
Offline Bankerdanny
  • Endeavor to persevere
Re: What kind of plastic are CB750 side covers made from?
« Reply #1 on: August 08, 2018, 06:30:15 PM »
It is much more expensive, but I would just order a replacement from Frankenfrankenstuff. I had a broken tab on one of my '76F covers and the other wasn't in great shape, so I bought a pair from him. The cover is made of sturdier stuff than my original and should hold up much better.
« Reply #2 on: August 08, 2018, 11:13:11 PM »
ABS  and Bankerdanny is correct.
« Reply #3 on: August 09, 2018, 02:49:50 AM »
Yamiya750.com sells the same plastic as Honda delivered. Same color too.
Fiberglass would be more durable.
AwesomeCB
« Reply #4 on: August 09, 2018, 02:53:22 AM »
If the paint on your cover is fine, then I would try fixing it before buying a new cover and paint. I recently learned of using super glue (any popular brand, I think) and baking soda to repair plastic parts. I repaired a piece of a side panel using that stuff and it's rock hard. It can be sanded and shaped like hard plastic. I also used filler to get the surface smooth but if you're more patient than I am, you probably don't need it.  It might work in your situation if you use some tape or other material to make a form for the tab. I've never had any luck using epoxy for tabs -- doesn't hold for long (could be operator error, who knows).
« Last Edit: August 09, 2018, 03:02:34 AM by AwesomeCB »
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: August 09, 2018, 07:01:51 AM »
Replace it with something new if it is original and hang it on the wall.
40+ year old abs never holds up well.
Offline rotortiller
« Reply #6 on: August 09, 2018, 08:43:02 AM »
Had very good results with this product. Cannot tell the difference from a stock unit when painted. Much better plastic too.  http://lpmreplicaparts.com/products.html
Offline kpier883
  • is quite the
« Reply #7 on: August 09, 2018, 09:16:04 AM »
I repaired a broken tab on a CBX side cover (not sure if it is the same material or not) using this product.  Repair completed in April of 2010.  No issues so far.  Available at many locations including Tractor Supply.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline tlbranth
« Reply #8 on: August 09, 2018, 10:27:33 AM »
Make a tab from a piece of ABS sheet or ABS pipe and weld it on with ABS solvent.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline carnivorous chicken
« Reply #9 on: August 09, 2018, 12:18:04 PM »
I'm gonna second Awesome -- no need to by a new one if your original is fine (and matches paint-wise). I've used epoxy to repair tabs on side covers and works just fine.
Offline imgnr
« Reply #10 on: August 10, 2018, 01:59:22 PM »
Buy a roll of fiberglass drywall repair tape and use it as backing when using the epoxy.  I just did this and adds a lot of strength.
I'm like the cat lady but with motorcycles.
Offline Marks78
« Reply #11 on: August 10, 2018, 05:21:25 PM »
Another option:
www.polyvance.com/PlastiFix-Kits-1/
I used this with great results to create a missing bolt-hole tab on the front fender of my 2006 GoldWing. Missing due to its having been broken completely off. Very impressive stuff! But not the only option that works.
Current Stable:
1978 CB750K
1982 XT200J
1982 XJ1100 Maxim
1985 V30 Magna
1998 VT1100 Spirit
2006 GoldWing
