Author Topic: Yamiya750 Body Set  (Read 1306 times)
Offline Jeff10
Yamiya750 Body Set
« on: August 14, 2018, 12:00:14 AM »
Hi:
First post here ever! Special thanks to this group for allowing me to lurk for the last few years. The advice and notes on this forum helped me restore and build 4 bikes including the 75 & 71 in the photos.
The Planet Blue 75 has a Body Set from Yamiya750. You have to be okay with the right side petcock on the newer bikes and as indicated here and elsewhere, there are fitment issues, but the effort to get it done, for me was worth it.
I did consider sealing up the right side petcock boss and welding in a bung on the left side for the correct petcock. I decided against that – between the fact that the tank was not designed with the proper area for the bung and the risk of paint damage made this option a nonstarter for me.
The petcock mounting boss on the Yamiya tank places the petcock's back fuel outlet within 2 - 3 millimetres of the carb linkage and even then you only get that clearance if the carbs are mounted to the bike dead level - even the slightest upward angle at the back of the carbs ends up with linkage to petcock contact. Solving this requires some careful adjustment (turning) of each of the intake boots after the carbs have been mounted – I was quite surprised at just how much angle adjustment I actually got. It also means that the air box ends up with a slight angle (given the lines on the side of the airbox, this is especially noticeable). I'm going to fab up some longer mounting brackets for the top of the airbox so I can get it back to level again so it looks right. Additionally, installing the tank cap was a bit of a struggle as the hinge pin boss had been welded in place slightly on an angle, but a little perseverance with a small drill bit in a pin vice got that done too.
The tank is slightly smaller overall than the stock Honda tank (I'm guessing it holds a bit less fuel). It is a bit narrower and doesn't look quite as tall – but you don't notice this unless you have the tank side by side with a stock unit. The inside (where it mounts over the frame tube) is definitely on the narrow side – work and patience was required to get the tank to fit over the wire harness, ignition switch wiring and throttle cables. I ended up with an additional challenge here as I chose to wire up a Powerlet 12V outlet which added another wire to navigate the tank over.
Appearance wise, the tank is very nice. The paint is smooth and deep and decals look great. The other parts in the set: headlight ears, headlight bucket and side panels are overall very nice pieces – the fit was good and the quality seems to be top notch. The emblems in the pics are all from Yamiya as well.
Re: Yamiya750 Body Set
« Reply #1 on: August 14, 2018, 04:38:42 AM »
  Look like a couple of great 750's. Nice job !   Glad you came out of the woodwork Jeff and showed your work  :D  Bet somebody wants a close-up of that red K1 also  ;)
« Last Edit: August 14, 2018, 04:40:43 AM by ekpent »
Offline emlupi
« Reply #2 on: August 14, 2018, 05:39:44 AM »
Very nice work, indeed. I like your touring setup on the blue bike.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: August 14, 2018, 07:15:31 AM »
Its a shame that similar sets aren't available for the Super Sport models too since the tanks seem to rust out more frequently.
« Reply #4 on: August 14, 2018, 08:34:42 AM »
I didn't realize the Yamiya tanks were not true to spec, but I've never used one.  At least they got the length correct so there are no spacing issues with the seat.
Offline beemerbum
« Reply #5 on: August 14, 2018, 08:45:45 AM »
How about a picture of the red '71?
Offline Jeff10
« Reply #6 on: August 14, 2018, 09:24:59 AM »
The Candy Ruby Red 71. I got "Scarlet" from a guy who was about to cut her up and turn her into a Bobber. He had lost interest and was looking for a quick sale. Originally, I went to look at it because he told me that the tank he had was "candy apple red and mint". He was right about the condition. I bought the tank and got the frame, engine, front end and some other bits & pieces free with the deal. He also had the original plastic chain guard – he thought it was a cheap reproduction and was going to throw it away! 2 winters and some depletion of the bike build bank account and I ended up with what you see in the pic.
The pipes are 341's in very nice condition that I ended up with along the way. I'd love to have a set of the correct 300's but every time I think I'm ready to spend the money on them, the fiscally responsible part of my brain kicks in and says "whoa there buddy!"
The bike runs, stops and drives and elicits lots of conversation with other old guys like me wherever I go with it. There is definitely something about that red – lots of ladies, young and old, comment on it too.
