Author Topic: Worth a Weld? Cracked frame tube at center stand mount  (Read 908 times)
Offline Lupo_00
« on: August 20, 2018, 03:52:42 PM »
Further down the rabbit hole...
You guys think this frame is still salvageable?
Offline calj737
  • I refuse...
Re: Worth a Weld? Cracked frame tube at center stand mount
« Reply #1 on: August 20, 2018, 04:22:54 PM »
Cut that section out, get some new 1-1/4” 0.063 tubing, and have it welded in. You’ll be fine. I made the exact same repair two weeks ago for a CognitoMoto bike.
Offline 540nova
« Reply #2 on: August 20, 2018, 05:31:10 PM »
Where are you located?
Sent from my SM-G955U using Tapatalk
Offline Lupo_00
« Reply #3 on: August 21, 2018, 05:17:14 AM »
Awesome thanks. This is happening today!
(New York)
« Reply #4 on: August 21, 2018, 03:53:23 PM »
Check the area forward of the side stand mount, they like to rot there from water in frame.
Offline Lupo_00
« Reply #5 on: August 21, 2018, 05:27:55 PM »
Thanks man. Looked it over today with a welder buddy and took care of the main issue and found another baby hole somewhere around there we plugged. I’m back in the game! Now to deal with the sludge...
« Reply #6 on: August 21, 2018, 07:40:15 PM »
I install 'drain holes' just in front of the lower front engine bolsters on the 750sI work on. For a while on the K1, Honda forgot to install those holes and the frames rotted right there: later ones have vent openings around the wrap-brackets where the frames are welded together, instead of drilled holes, to dry them out. We had a mimeographed (remember those, guys?) 'Bulletin' from American Honda (1972 March) to check that all CB750 frames had these holes, and they were 'clear'. The 'excuse' was that the holes were painted shut: somehow that paint still made steel chips when I drilled it out...  ::)
Offline Lupo_00
« Reply #7 on: August 25, 2018, 10:27:56 AM »
Good call, thanks Hondaman.  I’ll take another look for those “existing” holes too...
