Author Topic: Has’t Run in 41 years  (Read 1428 times)
Offline rider52
« on: August 20, 2018, 03:56:06 PM »
I am on the trail of a 1975 CB750 that has 3000 original miles on it and hasn’t been started in 41 years. I have not yet seen the bike but expect it to be neglected and not abused. It is the original owner and I believe the owner to be honest. Although I have ridden for 43 years, I am brand new at the resto game.
I am comfortable assessing the bike visually but need help beyond that.....so...two questions.
1. What should I look for before making an offer...what tests could I easily perform?
2. If I buy, what likely challenges lie ahead?
Thanks in advance for any help.
Re: Has’t Run in 41 years
« Reply #1 on: August 20, 2018, 04:02:45 PM »
Make sure the engine turns over. Check the tank interior for rusting! Hopefully it wasn't put up with gas in it which would probably necessitate a replacement tank.  Also expect to go through the carbs unless it was stored properly with dry carbs and tank.
With 3000 miles you could get very lucky. Buy a new battery, put gas in it and start it up! You may be surprised. If so plan on doing a complete tune up by the book and brake flush/fluid change.
« Reply #2 on: August 20, 2018, 05:34:36 PM »
do a little research on what parts are expensive to repair or replace and make a realistic plan about what level of restoration you are prepared to do
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #3 on: August 21, 2018, 05:11:29 AM »
Before you try to turn the engine over, squirt some Marvel Mystery Oil into each cylinder and let it sit for a while (preferably over night).
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #4 on: August 21, 2018, 06:11:41 AM »
 Be cool to see how this turns out. Be sure to take your camera when you go look so we can all have a peek. Hopefully for you it will be a real gem and stored proper.
« Reply #5 on: August 21, 2018, 11:00:37 AM »
Hopefully plugs are still in it.
If they are, a cheap USB borescope ($13 amazon) is a good tool to have to check cyls and inside the tank.
Check for rust at lowest points of frame and exhaust.
« Reply #6 on: August 22, 2018, 09:16:37 AM »
Make sure the motor is not seized.  You can do this by using the kickstarter to see if the crank turns.
Offline 74cb750
« Reply #7 on: August 30, 2018, 02:17:04 AM »
All of them.  ;)
No Seriously, you're probably not going to know what it needs until you get it home to do a full assessment,
let me know what new engine parts you need as i have a bunch lying around.
michel
Laugh at least once a day.
Life  $ucks, then you die.
