Author Topic: New Record at Bonneville ACTUALLY 4 NEW RECORDS  (Read 9131 times)
Re: New Record at Bonneville
« Reply #25 on: August 28, 2018, 07:48:45 pm »
Updates?? Pretty pleeaze. ;D
« Reply #26 on: August 29, 2018, 05:12:10 am »
 Dennis  set another record yesterday,going for another today.
« Reply #27 on: August 29, 2018, 05:53:21 am »
Glad you made it there safely Frank!
Masterful tease Frank.
What class and bike? Streamline or non-streamline?
Details please, pretty please.
Congrats Dennis!
« Reply #28 on: August 29, 2018, 07:17:09 am »
Naked, the fairing has been off , before I got here.
 He ran a 136 yesterday, i believe he will try to crack the fuel record, using gasoline.
 Jerry pulled out this morning..
 Coolest I have see  it here for bike week, don't think it will break 90, yesterday or today..
Offline dragracer
  • CB750F Dragbike
« Reply #29 on: August 29, 2018, 12:01:37 pm »
Congratulations again Dennis. Making the SOHC crowd stand up with pride.
« Reply #30 on: August 29, 2018, 06:24:04 pm »
Saturday morning first run netted the 138 then the back up return run was the 147.8 with NO changes. We didn't see enough 147's!
Epic battles with the Triumph. They were getting some air time from the announcer.
« Reply #31 on: August 29, 2018, 06:29:54 pm »
Jerry, i spent most of the afternoon pulling  the Preachers top end off..836. Ha..
  • Moderator
« Reply #32 on: August 30, 2018, 02:41:14 am »
Frank, what was the Preachers 836 ?
« Reply #33 on: August 30, 2018, 09:58:16 am »
Did you ID the cam? So stock engine with 836?!
Sam, that bike was a built-for-show bike. Cafe Racer TV. It had so many inaccuracies and BS it was ridiculous. One article said it had a RC Cobra 826 and another said it had a RC Cobra 936. It said that Larry Spiderman McBride built the carbs at a race. That was the funniest one  ;) Said it had a MTC tranny and Fast by Gast built the engine. Also it said Mikuni carbs but they are Keihin CR and they didn't know what size. He ran it in 1000 fuel class and barely managed to set a record at 109. It's really making me think of getting my 1000 out there.
  • Moderator
« Reply #34 on: August 30, 2018, 03:42:15 pm »
Jerry, as you know, my drag bike would run that speed at the 1000 foot mark, haha.
I guess you weren't there when we had a run in with this Preachers crew and Cafe racer TV at Valdosta or you would have remembered.
The lads spent most of the day setting the bike up for them so that Rickey Gadson could ride it on the Monday and compare it to a modern day Kawasaki who Gadson is sponsored by.
They/we eventually got it running in our pit and it was real noisy. I reached into the tool box for a long plastic handled screw driver that we had to use as a stethoscope on the motor to pin point the noise. just as I was about to put the end in the region of the cam chain, I noticed there was no oil pressure on the gauge and at that moment, the motor cut out anyway because they had not turned on the gas. hahaha.
The screw driver was about a foot long so I dipped it in the oil tank and it came out bone dry, hahaha.
I'm not sure they should be reality TV motorcycle builders, they would be better off making Westerns as they are nothing but a bunch of Cowboys.
I have a couple of pictures of them with us but they are in my old computer until I can get them transferred.
P.S. They also said that Larry had rebuilt the carbs on this one. hahahahaha.
« Last Edit: August 30, 2018, 03:44:50 pm by Sam Green Racing »
« Reply #35 on: August 30, 2018, 05:51:08 pm »
It had a pretty lumpy cam . I did not see any I'd markings but did not pull the washer.. stock cam sprocket.
 Cam looked a bit like a grey coating, but no flat with the grind marked on it like Norris.
Dennis thinks intakes may have been oversize,  but chambers looked untouched. I forgot to check the ports.
 It had red valve retainers, so maybe RC springs.
 And it had the CR carbs.
 Nothing too crazy in there..
Last night we went and had a few beers, Terry and I... the Preacher name never came up through the whole thing.
« Reply #36 on: August 30, 2018, 06:18:19 pm »
 The last bike in teardown today was a 550 Honda with velocity stacks and slash cut drag pipes.
 It ran  117 mph... wtf....
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #37 on: August 31, 2018, 05:23:38 am »
In 2nd gear!  :o  ;)  ;D
TAMTF...
Wilbur
Projects:
                                           http://oldmanhonda.com/MC/wiring750K1.html
Sent from my Tandy TRS-80!
Offline NickO
« Reply #38 on: August 31, 2018, 06:50:26 am »
If somebody can give me the:
1. primary reduction ratio
2. 5th (top) gear ratio
3. Precise circumference of the back tyre
I can provide a gearing chart for you. This will show the top speed for a given RPM for various combinations of final drive reduction.
I've already done the hard work years ago for a mate who races on the roads and it's been accurate to within 1 mph @ 140mph (logged on a GPS).
« Last Edit: August 31, 2018, 06:56:16 am by NickO »
UPDATE!! 4 (FOUR) New RecordS at Bonneville
« Reply #39 on: August 31, 2018, 09:01:26 am »
Just got off the phone with Dennis. He's been driving all night and is already in Minnesota. He said "when I left The Salt we left with FOUR new records. WooHOOOOOOOOO!!! A great year. Not bad for an old 750. The Triumph trident got shut out  ;) ;D
« Reply #40 on: August 31, 2018, 05:08:34 pm »
WFO baby. Awesome Dennis!  8)
Offline BPellerine
« Reply #41 on: August 31, 2018, 05:33:58 pm »
I read the write up a couple years back on that bike,engine was described as a ''rare'' golden rod motor,whatever that is,not all that fast for all the hype.bill
1978 CB 750K ard and webers
another anfob
« Reply #42 on: August 31, 2018, 05:42:34 pm »
1. 1.708
2a. 4th gear 1.097
2b. 5th gear .939
3. plug in a circumference of 80" as a guesstimate, with 4th gear and a 17/48 final drive, and I'll see how it compares with my dyno readings.
Offline NickO
« Reply #43 on: September 02, 2018, 03:57:45 am »
1. 1.708
2a. 4th gear 1.097
2b. 5th gear .939
8,000 RPM
4th 114.5
5th 133.8
8,500 RPM
4th 121.7
5th 142.2
9,000 RPM
4th 128.9
5th 150.5
Offline Bill/BentON Racing
    • BentON Racing
Re: New Record at Bonneville ACTUALLY 4 NEW RECORDS
« Reply #44 on: September 02, 2018, 04:03:35 am »
Congratulations Dennis and Dave
BentON Racing Website
BentON Racing Facebook
Offline Old Scrambler
« Reply #45 on: September 02, 2018, 08:39:13 am »
Jerry..............I think it was 3 records.......we missed the M-CG by 3-tenths.  Could have gotten it with a run on late Wednesday, but did not know at the time I chose to tear down.
Thanks to all for the attention and the calculations.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #46 on: September 02, 2018, 08:42:47 am »
More incentive  ;)
« Reply #47 on: September 02, 2018, 07:26:33 pm »
1. 1.708
2a. 4th gear 1.097
2b. 5th gear .939
8,000 RPM
4th 114.5
5th 133.8
8,500 RPM
4th 121.7
5th 142.2
9,000 RPM
4th 128.9
5th 150.5
My dyno said, with 4th gear and 17:48 sprockets:
8000 98.3
8500 105.2
9000 111.1
I also measured the rear tire by wrapping a string around the center of the tire tread and came up with 82 3/4".
Offline kmb69
« Reply #48 on: September 02, 2018, 07:59:29 pm »
8000 98.3
8500 105.2
9000 111.1
What is "My dyno"?
What accounts for the lower mph compared to actual gear train calculation?
« Reply #49 on: September 02, 2018, 08:09:29 pm »
8000 98.3
8500 105.2
9000 111.1
What is "My dyno"?
"My dyno" is a Dynojet 200i. ;) My MPH was measured, not calculated.
