Author Topic: m unit shadow vt600 1997  (Read 672 times)
Offline Probleme
« on: August 27, 2018, 08:29:24 PM »
Hi ! i dont know if i am the right place, and sorry for my english ( i am french ) but i really need help !
i try to install a m-unit blue on my shadow 600 and i dont understand why my m unit doesnt start ! i follow must tutorial and over video, but i am block ! this is my wired and my diagram
Offline Probleme
Re: m unit shadow vt600 1997
« Reply #1 on: August 27, 2018, 08:33:14 PM »
my ignition
Offline Probleme
« Reply #2 on: August 27, 2018, 08:34:45 PM »
my actual diagram ( for the ignition )
Offline Probleme
« Reply #3 on: August 28, 2018, 08:56:08 AM »
yeah ! its works ! just connect the m-unit positive straight on the battery ! ignition switch work ! i can start ... connect the coil .... thanks !
Offline Probleme
« Reply #4 on: August 28, 2018, 10:29:32 AM »
oh sorry ! wrong explain ! i connect my m-unit straight on battery, but my key switch is connect and work.
Offline Probleme
« Reply #5 on: August 28, 2018, 11:08:14 AM »
to clarify, yes i connect positive and negative straight to battery to test m-unit, m-unit works !
after, i connect key switch to m unit positive and BLACK wire to m-unit lock ! and its work ! when i turn my key m-unit start ! is it good ?
