Author Topic: CB500 Four K1 1972, currently mid mono-shock, working on engine  (Read 11500 times)
Offline Register
Re: CB500 Four K1 1972, currently mid mono-shock, working on engine
« Reply #50 on: January 12, 2020, 11:52:05 PM »
Photos
Offline Register
« Reply #51 on: January 12, 2020, 11:55:41 PM »
Photos
I’ve loads more of various stages of disassembly if anyone wants to see them.
Offline Register
« Reply #52 on: March 09, 2020, 11:53:28 PM »
Replaced the chainring and sprocket.
Certainly reduced some of the free play at the drive shaft.
Offline Register
« Reply #53 on: March 15, 2020, 12:41:50 AM »
Not sure about this lot.
Over enthusiastic shambles on eBay.
Speedo is kph and tacho is electrical.
Off the scale incompetence.
Also looking a bit small maybe?
I can live with kph but is it poss to get a signal to the tacho some how?
Offline Register
« Reply #54 on: March 21, 2020, 05:25:21 AM »
Thanks I’ll give that a go.
Is there any risk of half revs off one coil or do I link to both?
Offline Register
« Reply #55 on: March 22, 2020, 01:43:23 AM »
Terrific, thanks gradually getting there. Currently sorting real wheel, sprocket, chain etc.
Planning lithium battery, just working through some conflicting information or reg/rec replacement.
Offline Register
« Reply #56 on: March 22, 2020, 09:16:21 AM »
Sheered a bolt in the clutch centre plate - part No. 22120323010.
Anyone got one for sale?
Thanks
Offline Register
« Reply #57 on: March 22, 2020, 10:29:09 AM »
Scratch that, all sorted
Offline Register
« Reply #58 on: April 05, 2020, 06:03:55 AM »
Thanks to whomever gave me this piece of advice.
Bit of welding and fit fine without the rubber washers.
« Last Edit: April 06, 2020, 11:49:10 PM by Register »
Offline Register
« Reply #59 on: April 08, 2020, 04:06:28 AM »
And now this lot.
Offline Register
« Reply #60 on: April 09, 2020, 02:02:40 PM »
Anyone see a problem with this set up?
Offline Register
« Reply #61 on: April 26, 2020, 02:33:07 AM »
Still creeping forwards.
Got to the unintelligible ugly stage.
Ricks regulator - I understand the bit where you match the 5 and 3 cables up but could anyone clarify what’s meant by the attached photo from their site......
‘DO NOT wire in at the 8P connector......’
I assumed that I just reconnect these to their other halves.
Is that not right?
Thanks
Offline Register
« Reply #62 on: May 10, 2020, 02:54:33 AM »
Still struggling with the wiring but it now turns over and the oil light goes out.
Not that you can tell from the photos.
Could someone remind me when the ignition light comes on and goes off?
Currently nothing.
Thanks
Offline Register
« Reply #63 on: May 17, 2020, 01:21:56 AM »
Sorry, my previous post makes no sense as I refer to ignition light but mean neutral light.
1 week later and still having no success I can't get any power at the points. I have continuity (blue and yellow) from coils to points
In summary, I have;
ignition - cranks well, oil light goes out promptly
headlight - main and low beam ok
indicators - front only, not flashing. Rears not connected
horn - makes a noise
no neutral light - bulb ok
And a spare black terminal on the harness where the coils join.
Any help appreciated thanks.
Offline Register
« Reply #64 on: May 24, 2020, 01:08:44 PM »
I think I’ve got the wiring sorted. Everything works but I’m not sure it’s as it should be.
ignition on powers the starter motor but the kill switch powers the coils/points even if ignition is off?
Do I have it right?
Finally got the exhaust on.
If I can find the plug spanner I’ll have a go at staring it tomorrow.
Thanks
Offline Register
« Reply #65 on: May 26, 2020, 03:55:56 AM »
Now running for first time since 2012 and in much need of a silencer.
Answered my previous question - switching the ignition off doesn’t stop the engine. Only kill switch does.
Assume I just need to find a switched power to the kill switch and that will bring everythinG to spec
Offline Register
« Reply #66 on: May 26, 2020, 04:42:34 AM »
Sounds like this
Offline Register
« Reply #67 on: May 30, 2020, 06:28:21 AM »
What looks like a pattern part coil (shorter length) just fried itself. Too hot to touch, now nothing.
Anyone know if I can run incandescent indicators up front with LED at the rear?
Thanks
Offline Register
« Reply #68 on: May 31, 2020, 05:28:00 AM »
I could use some help on the brake callipers.
I plan to run with banjo fitting direct to calliper.
Anyone got a method to remove the insert that’s preventing the bolt from running in?
Thanks.
« Reply #69 on: May 31, 2020, 06:16:53 AM »
I used a drywall screw, maybe 1.5"?  Anyway, long enough that you have something to grab.  Gently screw it into the insert, then lever it out with some pliers.  I don't remember it taking a whole lot of brute force, but it has been a few years since I did it.
Offline Register
« Reply #70 on: May 31, 2020, 09:22:25 AM »
Thanks. Assume the insert is press fit, not threaded?
Also there’s a small lip on the calliper did you bother to file that off or just seat the copper washer in there?
Thanks
Offline Register
« Reply #71 on: May 31, 2020, 10:03:10 AM »
Worked like a charm. Thanks.
« Reply #72 on: May 31, 2020, 10:34:42 AM »
I did not file the lip off, as I was not intending to use a banjo bolt...i used 2 hardlines on my dual disc setup.  I just needed to move the insert to the bleed screw hole so both sides would be symmetrical.
« Reply #73 on: May 31, 2020, 10:37:08 AM »
Also, check the bike out in bike of the month.  Close battle going on.  Could use a vote.
Offline Register
« Reply #74 on: June 01, 2020, 01:21:46 AM »
sorry, missed this, voting closed.
Terrific bike.
i could never have got behind those rectangular mirrors.
