Author Topic: Anyone here have any experiences with the CBX 1100?  (Read 3421 times)
Offline cliffN61
« on: September 03, 2018, 06:22:44 PM »
I was just thinking of looking for one to restore and have zero experience with them. Curious if anyone else has and what their thoughts are on them?
Re: Anyone here have any experiences with the CBX 1100?
« Reply #1 on: September 03, 2018, 11:58:03 PM »
mate of mine has a pristine cbx 1000 6 cylinder if that's what you mean?,if you buy a rough one that needs engine work be prepared to start spending money real quick,nice bikes.
« Last Edit: September 04, 2018, 12:02:03 AM by dave500 »
« Reply #2 on: September 04, 2018, 12:17:19 AM »
 That's a lot of carbs to tune. My buddy had 2 sets of vac gauges for his. Don't ever let them gunk up especially after you've gone through them once.
« Reply #3 on: September 04, 2018, 12:59:24 AM »
you have to unbolt the motor and lay it forward to adjust the valves!
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ec5722nvnvs66nc7tqtkcm63i3&/topic,60973.0.html
« Reply #4 on: September 04, 2018, 01:32:56 AM »
bay a running one.
..sleepers is to expensive to vake up.
..leaking carbs..dryed up rubberparts..intake /airfilter rubber rotten fast..and carbs gunk up in a fev month..,,so just a vinter sleep can give problems..
its a great bike in all vays...but the cost to hold it running..and the problems to hold it running(if you not use it evry weekend..) they just hate to stand still..
a sohc is just so more simpel and easy ...just turn gas on and fire up..even after 3 month...cbx is just in a heiger class..in good and badd...
cbx engines is not so komplikated..there is just just more of evrything..and it harder to come to the Things..specily the carbs,,,tilting the engine is easy..
i hate all this v-w.... vords
« Reply #5 on: September 04, 2018, 02:57:33 AM »
Cleaning 6 carbs once and you will appreciate that you do not wish to do it again. They are musical on full throttle application and pull like a freight train. CV carbs are very sensitive to blockage and will block when sitting too long so, keep them exercised and they stay happy. Some seafoam can keep them happy if used every tankful, it does the trick for many CV equipped CX-500, GL-500 and 650 owners along with Goldwing owners.
You will spend a fortune on a CBX not in great shape, save your change until you can afford the difference between a great running example and one that has sat or is not running.
« Reply #6 on: September 04, 2018, 04:18:15 AM »
 Member Mike Simon seems to have a lot of knowledge and experience on this model. He will probably chime in. See other bikes section also as somebody posted about just buying one recently.
Offline cliffN61
« Reply #7 on: September 04, 2018, 02:48:10 PM »
Thanks for all the replies, seem's like a much larger consideration than I had imagined. Since I live in a cold area my riding months are sort of limited so it seems that may be an issue for me. I love the look of the bike and of course the power but also not looking for a full time headache either.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #8 on: September 04, 2018, 04:14:21 PM »
I own 3 CBXes. Bought my 79 in Novemebr of 78, still own it. Restored and sold a few.
Any questions - fire away. If it gets too much for the forum here e-mail me at mike.simon70@yahoo.com
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline Trevor from Warragul
« Reply #9 on: September 05, 2018, 05:08:20 AM »
Not true!  You just have to remove two triangular frame hangers (three bolts each) and the tacho drive (two screws).  Easy!
Umh, if you want to replace one of the throttle cables, then it's best to drop the motor forward... (which is not as hard as it sounds).
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline Scott S
« Reply #10 on: September 05, 2018, 11:16:52 AM »
 Carb rebuilds by a pro will run you $800-1000.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline cliffN61
« Reply #11 on: September 05, 2018, 11:49:13 AM »
I have never laid eyes on them in real life so I am curious, I love what I see in pics and videos. Obviously you love them or you wouldn't own 3. What is your thoughts on buying one to rebuild compared to buying one finished already?
« Reply #12 on: September 05, 2018, 01:15:04 PM »
My general thoughts....
A good running bike will most likely cost less than find one in need of restore where lots of stock parts are missing unless you find one really cheap. My experiences of CB750.
I have a friend that has restored a few CBX so I know who to ask. I have seen and heard about the carbs with jets to be drilled, threaded and pulled out for cleaning. All shims to check and do properly. Cam chain tensioner was the question to solve when I visited him a week ago.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #13 on: September 05, 2018, 01:22:18 PM »
Trevor
Yeah! I want to see you getting the valve cover off without tilting the motor.  :o On how many CBXes have you done this?
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #14 on: September 05, 2018, 01:25:57 PM »
Only the CBX-Z or 79, first year model, has jets pressed in which need to be tapped and pulled for proper cleaning. Cam chain tensioner adjustment needs to be done properly and requires the correct procedure. Attempting to work on these bikes based on your skills and experience and WITHOUT the service manual is ill advised.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #15 on: September 05, 2018, 01:30:06 PM »
There is a significant difference in price between the four years for a "finished" bike. It depends on what you want and how much you want to spend. Working on one to rebuild can be very rewarding, but depending on the final goal, can be costly or maybe impossible due to parts availability. You need to do some research and set your sight on which year/model, then assess whether you want one to restore or want one that is ready to ride.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #16 on: September 05, 2018, 01:32:37 PM »
Coming back to the title of this thread: The bike's displacement nominally is 1047cc. It was always a CBX 1000, not 1100.
The 4-cyl DOHC "F" model with 1062cc was identified as a CB1100.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
« Reply #17 on: September 05, 2018, 11:19:27 PM »
heres some pics of my mates one,he paid 10,000 aussie for it which is dead cheap,it spent 10 years in a guys lounge room,its bloody great to ride but at 5 foot four inches tall its a bit big for me.
« Reply #18 on: September 05, 2018, 11:31:09 PM »
heres how I look on one,big bike if you ride it around town,i had no trouble once I was moving,i couldn't live with one though,we swapped bikes mine has a dash cam so heres a freeze frame,real quiet then look at the speedo!#$%*ing oops 140 kays came up real quick n easy.
« Reply #19 on: September 06, 2018, 12:31:25 AM »
Just one, which I've owned for thirty years...
I bought Mike Nixon's booklet "Adjusting the CBX Valves".  Maybe you should buy it too...
Oh, and the "Official Honda Shop Manual CBX" (3-10) has the same valve cover removal instructions as Mike's booklet...
« Last Edit: September 06, 2018, 03:17:34 AM by morini »
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
Offline seebee750
  • Vintage Honda Restorations at Crows Cycle Works
  • CB750 K0,K4,.CB500 K0,K2,CL175 K0 '79 CBX
« Reply #20 on: September 06, 2018, 03:13:46 AM »
I had six 1979s CBXs and one 1980. I kept the best one, a red 1979, and sold the rest. You need lots of patience, good mechanical skills and lost of cash. It is sometimes easier to find used space shuttle parts cheaper than CBX parts. Don't buy one that is not complete, is all I have to say.
They are not all the same!
Nothing is of great value until it is finished.
Offline dhall57
« Reply #21 on: September 06, 2018, 04:16:14 AM »
I have never had one, but always been fascinated by the look of the bike and of course the 6 cylinders and 6 carbs. 8)
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline strynboen
« Reply #22 on: September 06, 2018, 09:27:55 AM »
« Reply #23 on: September 06, 2018, 09:48:21 AM »
Dangerous thread. I have always liked a red -1979 with 105 hp, totally stock. A forum with all details explained and manual downloads should help to make me to fall over the edge...
Z1-900/1000 with modified engine is also on the list.... I have a CB750 K2 stock to put together first.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #24 on: September 06, 2018, 10:22:01 AM »
The ICOA (International CBX Owners Association) has an excellent forum with a lot of people holding extensive knowledge about the bike and its maintenance and service. Other than that, there are a lot of "experts" out there who read something or know someone who read something.
I still have to ride one of my CBXes anywhere without running into someone who tells me he owned one way back then, wished he would have never sold it and knows everything about it. Based on that, Honda must have made substantially more than the barely 40,000 bikes from April 1978 through January 1982. Beware of bad advice.
As I said before, if you want my personal input without having to argue with self-proclaimed CBX authorities send me a pm or e-mail me at mike.simon70@yahoo.com
« Last Edit: September 06, 2018, 10:25:21 AM by MikeSimon »
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
