Does it still have the stock cam?
Has it been degreed properly?
If the intake valves are closing late, the following compression stroke will push air into the intake runners and out the carbs, resulting in white puffs of atomized fuel/ air at the carb entrance.
The other possibility is bent valves that can't seal.
A compression or leak down test on each cylinder should yeild insight about that possibility.
