So here is the issue.
When I turn either left or right, the turn signal doesn't flash, stays constant. The running light comes on as usual when I turn the bike on. Also when I unplug the flasher relay, nothing change. Same symptoms. The turn light comes when I turn the L/R switch. That shouldn't happen right? Does that mean, there must be some shorting in the left hand control wiring?
Here is what I have done:
1. Changed to three prong electronic flasher relay (which i hear click when I turn the key on, and also when I turn the L/R switch. But just clicks once)
2. Opened the left control switch and cleaned it really well making sure the contacts were clean.
3. made sure all wiring were connected, and grounds are good.
4. Buzzer is not connected as of now (testing without it)
My lights aren't OEM and doesn't have the bucket ground wire, is that needed?
BTW, all my lights are LED, and I am testing it without connecting the rear turn signal (just front turn signal are connected). Should I test it with all lights connected, does it matter.
Thank you guys for all your help
