Author Topic: CB 500 weird alternator readings  (Read 5545 times)
Re: CB 500 weird alternator readings
« Reply #25 on: October 15, 2018, 08:06:05 AM »
Stock coils and points?
Offline Alex
« Reply #26 on: October 15, 2018, 09:33:04 AM »
« Reply #27 on: October 15, 2018, 11:06:54 AM »
The numbers seem good to me.  What is missing is voltage trend info while revving 4000-5000 RPM.  If it eventually stabilizes at 13.8 -ish, I wouldn't complain.
It also kinda matters if the lighting is on or off, as that can impact how hard the alternator has to work to maintain electrical happiness at any RPM.
Offline Alex
« Reply #28 on: October 20, 2018, 02:50:46 AM »
Yeah, weirdly enought, these are the best numbers I’ve ever received.
But I haven’t had it out for a longer test ride yet. I’ll have to see how it responds when it gets a bit warm, since it died on me last time I took it for a longer test ride.
I’ll try to get the 4-5k trend info this Sunday!
Well, the light turns on when hitting the ignition start. I may have to install a head light switch!
Skickat från min iPhone med Tapatalk
Offline remcoseegers
« Reply #29 on: October 25, 2019, 11:24:28 AM »
Old thread but I am facing exactly the same, measuring 1.2 Ohm on the yellow wires. Did you ever get to solve it? How?
Thanks!
Offline maxheadflow
« Reply #30 on: October 25, 2019, 05:47:51 PM »
It's the connectors.
