Author Topic: cb400f kick start pivot cracked  (Read 902 times)
Offline awrawr
« on: September 10, 2018, 01:20:47 PM »
I have two of these and they are both cracked. I assume this is a common fault but I cannot find any replacement parts for sale anywhere and a lasting repair seems unlikely, given the small size of the piece of metal that is broken, right at the point of maximum stress.
Has anybody solve this problem? Or know a source of replacements?
Offline robvangulik
  • Honda Fourever
Re: cb400f kick start pivot cracked
« Reply #1 on: September 10, 2018, 03:15:00 PM »
It is common alright, i welded it and grinded it in the right shape some 10 years ago and been OK since, i must say i hardly ever use it, it mostly starts electric first push on the button.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: September 10, 2018, 10:33:35 PM »
I've had 8 400 fours and none had a kick start problem.  Is the lever cracked?....Larry
Offline awrawr
« Reply #3 on: September 11, 2018, 12:17:22 AM »
See pic. I blame the crack on abuse arising from frequent dirty winter weather, salty roads, damp electrics and consequent difficulty starting. If all else fails I will try the weld since I do not anticipate using the bike in poor weather and should be able to rely on the starter button with electronic ignition, better maintained electrics and dry-running only.
I was surprised after-market replacements are so hard to find.does anyone know of an alternative model with a matching part? There's several look-alikes but difficult to judge diameters and angles from pictures.
Offline robvangulik
  • Honda Fourever
« Reply #4 on: September 11, 2018, 02:34:51 AM »
Here is my welded kicker..
Offline jakec
« Reply #5 on: September 11, 2018, 09:06:10 AM »
My roommate's 400F has a totally incorrect kickstart lever, a small one like for a small twin. I always wondered why this would be the case but maybe his was broken in the past.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline awrawr
« Reply #6 on: September 11, 2018, 09:25:17 AM »
Maybe it's just God's way of telling me to lose weight and keep my timing and carbs properly adjusted............
Offline Bodi
« Reply #7 on: September 11, 2018, 09:35:26 AM »
I believe this is just a weak point. Mine cracked, I rooted through several huge bins of kickstart levers (hundreds of them) at two local bike wreckers and did not find any 400F ones or any others that would work. I had it welded two or three years ago, and this year it's cracking open again. I will try and have it welded again but rely on electric start for cold starts now - this is when a lot of kicks would be required, I always kicked it over for this to save battery charge.
Offline carnivorous chicken
« Reply #8 on: September 11, 2018, 10:28:32 AM »
Pretty sure I've got a kicker if you need one...
