Author Topic: Broken triple clamp cb 750  (Read 1568 times)
Offline aminemed
« on: September 16, 2018, 02:16:52 AM »
Hi all
Just discovered that my cab 750 K2 upper triple clamp is broken (see picture). Can I weld it ? Or drive with it for a short time until I find another one.
What is pissing me off is that the D washer was there and that I just fitted this upper tree 2 months ago
« Last Edit: September 16, 2018, 02:21:27 AM by aminemed »
Offline pjlogue
Re: Broken triple clamp cb 750
« Reply #1 on: September 16, 2018, 03:19:55 AM »
I would replace it.  Triple clamps are readily available on fleabay.  You could probably gently  ride it like that but I would not.  Unexpected pot hole or other heavy stress situation and who knows what would happen.  Just not worth the risk.  It would be like driving a car with a broken steering knuckle.
-P.
« Reply #2 on: September 16, 2018, 03:46:57 AM »
I rode Dorothy for a while before i found the top bracket was broken. Get a new one, once you know about it, riding is not the same.
Offline rotortiller
« Reply #3 on: September 16, 2018, 03:49:03 AM »
Can I weld it ?
Yes it can be welded and is done often enough. I had one on a Kawasaki H1B that snapped several years ago that is welded as I could not find a replacement. You need a good welder/machinist and understand why it snapped  (lack of spacer washer etc). Again, you need a professional welder with something like this. Lots of structural stuff is welded and common place.
« Reply #4 on: September 16, 2018, 06:25:21 AM »
  Looks like since yours is machined custom and does not use the stock gauge clusters etc. that you could fit a later model 73-76 top triple which are way cheaper then the 1972 "unicorn" clamp and much more plentiful.
Offline aminemed
« Reply #5 on: September 16, 2018, 08:16:08 AM »
Any idea on why it broke ? D washer was properly fitted.
I'm gonna look for a new one, i understand that welding it is not a wise idea
« Reply #6 on: September 16, 2018, 08:27:41 AM »
 One of my bikes has aftermarket tubes, I can only assume they are bigger OD, I have D washers but they don't close up tight without breaking the top tree. consider making thicker washers and pay attention to the torque on the bolts.
« Reply #7 on: September 16, 2018, 09:09:45 AM »
Who knows after all these years but maybe when you remove it and do an autopsy you will see an air bubble or casting flaw. Maybe that machining you had done  when metal was removed increased the stress load a little bit.  Since its a cafe racer maybe you drive to fast and hard  :D
Offline cooldrum
« Reply #8 on: September 16, 2018, 01:31:41 PM »
My upper triple cracked in two places (right fork tube side on K4) with D washers in place.  May have been over torqued a bit.  So be aware of torque values.  I posted in "wanted section" for a replacement and a forum member had a spare for me.  I wasn't going the welded route for safety reasons.
« Reply #9 on: September 16, 2018, 06:07:43 PM »
I have a spare modified [cut] triple top from an early K...
« Reply #10 on: September 16, 2018, 06:27:53 PM »
They are not cast i bet.. forged they should be..
 Otherwise they would all be broken by now..
Offline tlbranth
« Reply #11 on: September 16, 2018, 07:06:47 PM »
Let me throw out an opinion that'll run contrary to popular dogma.
The store-bought d-rings are a waste of money.
The lower clamp can be cinched down tight because it's steel. This keeps the forks from moving vertically and helps some from horizontal movement.
The uppers don't need to be bolted down tight. They're there to prevent horizontal fork movement and snug will do it. Make your own d-rings from washers. Try different thicknesses and sand down where necessary so you can tighten the bolts with just a snug fit on the fork. More stress on the clamp  adds nothing to fork stability.
My opinion. Flame away.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline jaytee-nz
« Reply #12 on: September 16, 2018, 07:31:52 PM »
I agree - why else would Mr Honda make the upper clamp out of crappy alloy (and it is s*&t if you have ever tried welding one) and the bottom one out of steel ?
« Reply #13 on: September 16, 2018, 08:26:52 PM »
Look at a Beemer top clamp from the 80,s....
Always wondered how much does this hold from twisting..
« Last Edit: September 16, 2018, 08:29:41 PM by 754 »
