Author Topic: The South Side Dive Bar  (Read 3041105 times)
Offline Damfino
Re: The South Side Dive Bar
« Reply #24175 on: February 18, 2010, 05:43:54 PM »
Uhhhh, don't you mean your 'micro penis?'
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #24176 on: February 18, 2010, 05:44:59 PM »
yeah that one.
  • Like a well oiled
    • Undead Asphalt
« Reply #24177 on: February 18, 2010, 05:47:00 PM »
did you see the burnout?
Offline Damfino
« Reply #24178 on: February 18, 2010, 05:52:57 PM »
Yeah, as a long time owner of Chevy & GMC vans, (I've had 4, my first was a '77 shorty & my current is a 2008 express) I can say it ain't easy getting them to do a burnout. Especially a fully loaded conversion. My '77 shorty was the only one I could get to do a burnout. I think my current one has the power, but it's strapped with traction & stability control.   :P
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
  • Like a well oiled
    • Undead Asphalt
« Reply #24179 on: February 18, 2010, 06:06:50 PM »
mine does burnouts real easy.
« Last Edit: February 18, 2010, 08:23:47 PM by Industrial Cafe »
Offline mark
« Reply #24180 on: February 18, 2010, 06:19:53 PM »
your sh!t is too new.
my buddy had a '68 G10 with a 230 and 3 speed that would do burnouts all day with skinny tires.
put fat tires on and pop the clutch a couple times and it would bounce the front end a foot off the ground.
his was Army green - think he paid $300 at the phone company sale.
 :P
F you mark...... F you.
  • Like a well oiled
    • Undead Asphalt
« Reply #24181 on: February 18, 2010, 06:32:09 PM »
the express van supposedly has a 5.3L 300hp motor...  which motor do you have?
Offline 333
  • Time for change
« Reply #24182 on: February 18, 2010, 07:22:05 PM »
I think that was the first video I've seen with Brian were he had a shirt on.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mick750F
« Reply #24183 on: February 18, 2010, 07:23:43 PM »
   Yeah but he just left a little while ago.  ::) ::)
Glosta, MA
  • Like a well oiled
    • Undead Asphalt
« Reply #24184 on: February 18, 2010, 07:31:36 PM »
Man it was freezing (65) out there today!!!!
Offline Frankenkit
  • Industrial Strength
« Reply #24185 on: February 18, 2010, 07:36:01 PM »
ok I have a quick question, but I don't really want to make a whole new thread or anything. (lazy...)
On my 350's left crank case cover (over the front sprocket, shifter etc) there's a bolt hole that's all stripped out.  I drilled it out, ran the tap, and tried helicoiling it.  For whatever reason, the helicoil always gets real hard to turn by the end and then snaps, with a couple threads still exposed.  This is really chapping my ass because I did this three times.  After the helicoil tab breaks off, I end up carefully winding the thing out and trying again.  Part of the problem is that the hole is sunk 1/2" deep, because a round metal sort of dowel fits in there around the bolt (sort of, anyway) so this narrow depression all around the hole makes it impossible for me to use the little keyed metal implement that supposedly pushes on the helicoil insert and makes it go into the newly-created threads.  I'm getting pissed and hoping that I don't have to just go ahead and drill it a little bigger and use a bigger bolt, like an m8 maybe.  (or could I fit an m8 in the tapped threads for an m6 1.0 helicoil? M6/1.0 is the ID, but what's the OD?) I guess it wouldn't matter if I had to go up a size, because it doesn't have to match, and I have a little metal around the sides but I don't wanna overdo it and #$%* up the case.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline mark
« Reply #24186 on: February 18, 2010, 07:42:21 PM »
if it isn't breaking because the threads aren't deep enough or some such...
file a step on the end of a bolt to look like the short plastic gizmo and install with that.
an m7x1 bolt might be close to the helicoil size.
Offline the technological J
  • deliciouso!
« Reply #24187 on: February 18, 2010, 08:16:43 PM »
hows this for painful
94 ST1100..Gone
72 750 K2 Stay tuned!
  • deliciouso!
« Reply #24188 on: February 18, 2010, 08:19:09 PM »
while im at it
94 ST1100..Gone
Offline MickeyX
« Reply #24189 on: February 18, 2010, 08:41:36 PM »
some #$%* at 503-616-9163 keeps calling my phone, 6-8 times a day. won't leave a message. when I answer, the #$%* hangs up on me. WTF??? I tried calling back and it says it won't accept incoming calls. I checked the # and lots of people are having this problem. I just put both of our cells on the do not call list. this is the same area code as we live in. #$%*er.  >:( >:( >:(
  • Like a well oiled
    • Undead Asphalt
« Reply #24190 on: February 18, 2010, 09:04:30 PM »
that's like the same deal I have with 312-219-something
http://800notes.com/Phone.aspx/1-503-616-9163
« Last Edit: February 18, 2010, 09:07:36 PM by Industrial Cafe »
Offline mrbreeze
  • Not your average
« Reply #24191 on: February 18, 2010, 09:45:40 PM »
only users lose drugs.
;D ;D ;D ;D.....I read this the other day and laughed(chuckled,guffawed,etc.).Never heard it before.
A couple more.......... a button I have ( remember the old commercial where the guy is frying an egg and he says "this is your brain" and then it starts sizzling and he says "this is your brain on drugs")....my button says " a mind is a terrible thing to confuse with eggs".
Hi......how are you???..........................How......high are you????
MEMBER # 257
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #24192 on: February 18, 2010, 11:44:35 PM »
It's me Mickey!
tag, you're it!
Offline MickeyX
« Reply #24193 on: February 19, 2010, 12:32:04 AM »
so my lunch break was over and I go back out to the tech area and my phone rings with the other # that's been bugging me the same way. this one is a chick from india. The other one is a guy from india. So I answer and she seems surprised. Then she goes into a shpeal about how she's from my credit card company and needs me to verify a few things from my account so I can get $50 of free stuff... blah, blah, blah... so I go off on her, right in front of my coworker/lead tech and then hung up on her. I'm going to report both tomorrow to the cell company and see what can be done. I'm sick of this #$%* and want them investigated. The 2nd # is 603-214-3330.
I'd tell you all the spam the hell out of them but then they would have your # too and probably bug the hell out of you.  >:( >:(
#$%*ers.
Offline Frankenkit
« Reply #24194 on: February 19, 2010, 12:40:03 AM »
let's sign their number up for updates etc etc on porn sites and free offers on whozits and whatzits online. Spam the #$%*ers right back.
1973 CL350- Lola?
Stuff for sale
Offline MickeyX
« Reply #24195 on: February 19, 2010, 12:59:04 AM »
I really love you.
Offline coldright
  • That's Ms.
  • to you
« Reply #24196 on: February 19, 2010, 02:28:56 AM »
#$%*ers.
Let's invite Seaweb and see what can be done... I like his style when it comes to this sort of thing.
  • Like a well oiled
    • Undead Asphalt
« Reply #24197 on: February 19, 2010, 05:29:38 AM »
I posted a thread on this issue last month....
edit:  http://forums.sohc4.net/index.php?topic=64757.msg709538#msg709538
« Last Edit: February 19, 2010, 05:31:36 AM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #24198 on: February 19, 2010, 05:32:34 AM »
I'd like to see if there's something that can be done. 'Firecracker' used to get info on people very efficiently.
I still get calls all night and day from 312-568-2199
« Last Edit: February 19, 2010, 05:34:39 AM by Industrial Cafe »
« Reply #24199 on: February 19, 2010, 06:53:07 AM »
thats a 312 ...... you could find um and i could go tap tap on they're door ...   "excuse me sir, are you the douche bag that won't stop calling my friend in Florida"
