Author Topic: The South Side Dive Bar  (Read 3036882 times)
Re: The South Side Dive Bar
« Reply #34975 on: January 05, 2011, 08:13:39 PM »
Offline 333
  • Time for change
« Reply #34976 on: January 05, 2011, 08:24:20 PM »
Okay, I want to thank you two for reminding me that I haven't worked in over 6 years.  I mean, life ain't too bad.  I am drinking champagne and eating chocolate croissants, but it is very cheap champagne, and the croissants are really stale and I had to make them chocolate myself.  But I'd really prefer to watch something AT WORK.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline SOHC Digger
  • I'm not an
« Reply #34977 on: January 05, 2011, 08:29:07 PM »
Chocolate croissants?  And champagne?
Offline 333
  • Time for change
« Reply #34978 on: January 05, 2011, 08:34:23 PM »
Yes.  You, too, could be unemployed and drinking cheap champagne and eating stale croissants w/ shaved Hershey bars melted on them.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #34979 on: January 05, 2011, 08:35:56 PM »
I made an omlette for supper tonight. I put pepperoni, american cheese and chocolate in it. (with Franks Red Hot Sauce as well)
« Reply #34980 on: January 05, 2011, 08:38:43 PM »
Offline Raef
« Reply #34981 on: January 05, 2011, 08:47:25 PM »
Hey, I only worked 800 hours, last year, in a tax paying honest to goodness job and 380 of those hours were in December.
 I think they could have a little more consideration, you know how hard it is to go from building a couple chimneys now and then and hanging out with all you fine fellas all the time to working 7 - 12's
it's "bull#$%*" really;)
Offline 333
  • Time for change
« Reply #34982 on: January 05, 2011, 09:11:13 PM »
Chimneys?  Oooo, now you've peaked my interest.  What do you know about venting one of these?  I have two fireplaces that I can't use because the house is so sealed up that the smoke goes up the chimney, and then gets sucked down the through the other flue or the furnace flue, all of which are in the same chimney.  And I have had someone out to check the chimney, and it's okay.
Offline BeSeeingYou
« Reply #34983 on: January 05, 2011, 09:20:15 PM »
I just got a call this morning for a one week contract job in Puerto Rico for later this month.  I will be staying here with flight and all other expenses paid.  I tried not to sound to excited. :D  Putting in two small video conference rooms for a large med-tech company. We will be staying on the east coast near some good snorkeling so my gear will be packed. Looked at an aerial photo of the resort area and it looks like there is a reef off the point.
Offline BeSeeingYou
« Reply #34984 on: January 05, 2011, 09:29:43 PM »
Do you have an outside air intake for your furnace?  I have one directly into my furnace but another common option is to run a 6 inch insulated flexible duct from an outside vent into a 5 gallon bucket next to the furnace.  The bucket contains the cold air from spilling into the house.  Sounds kind of crazy but it works and is used often here.
« Last Edit: January 05, 2011, 10:24:48 PM by srust58 »
Offline the technological J
  • deliciouso!
« Reply #34985 on: January 05, 2011, 09:46:04 PM »
when im geeked about an offer i try my best to almost sound dissapointed about it...i havnt been able to put my finger on why maybe i think someone will say ok and  we'll cover your drinking tab and you can stay all you want
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #34986 on: January 05, 2011, 10:45:33 PM »
When I built my house  a few years ago they "made me" cut a big hole somewhere that was just vented to the outside.
I cut a 1 ft. hole under the fridge and vented it outside, air can then be sucked in and cool the fridge and also allows fans and chimneys in the house to function.
My fridge was in such a tight spot it still overheated, I then cut a hole through the back fridge / pantry wall and now all is well.
Air tight houses need large vents to the outdoors.
Offline mick750F
« Reply #34987 on: January 06, 2011, 04:31:08 AM »
   Wouldn't want to be around you this AM...
Glosta, MA
Offline Raef
« Reply #34988 on: January 06, 2011, 05:13:09 AM »
Have you ever tried cracking the door or window closest to fire places when this starts to happen? not saying this is an answer, it just my give some insight to what is happening.
Now days houses are sealed up so tight. I believe in most places it is now code that each firebox is to be vented (fresh air intake) directly to the out side. This keeps the fireplace from sucking the heated air out of the house and it also helps it draw. One of the most efficient ways to do this is to put a fresh air intake at the front of the fire box. I do this by running a small duct under the fire box and turning it up just inside the fire place doors or screen, it can be closed when not in use, on the other end it has a  vent on the face of out side wall.
I have retro fitted such things, depending on the location and layout, by cutting a hole in the back of the firebox and installing a stainless duct to the outside and attaching it to a small custom made manifold that lays in the bottom of the firebox.
I live in a very old house that is a little drafty, I will often open a fresh air intake for the furnace in the basement to pressurize my house, I know I lose heat but it is better than the cold coming in.
Mark
Offline Raef
« Reply #34989 on: January 06, 2011, 05:22:20 AM »
It also sounds to me that you may be calling a chase a chimney. Every thing that runs up the chase is exhaust I assume? no fresh air intake for anything?
Mark
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #34990 on: January 06, 2011, 05:31:04 AM »
I turn 40 today.  #$%*.
333:  Think "Shakeweight".
Offline Raef
« Reply #34991 on: January 06, 2011, 05:37:10 AM »
happy birthday...what took so long?
by the way it's all down hill from here :)
Offline Trav-i
  • Has finally become an
« Reply #34992 on: January 06, 2011, 05:50:39 AM »
Man this day is starting slow already, it's gonna be one long day.  I can't stand slow days.  :-\
Happy Birthday Cuppy!  I hit 3-0 last month.
Forum member #9962
1992 GL1500 Interstate
Offline Brown Bomber
« Reply #34993 on: January 06, 2011, 06:03:17 AM »
Happy Birthday CC!
You don't look a day over, wait that's a bloody cupcake. Never mind.
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Offline 333
  • Time for change
« Reply #34994 on: January 06, 2011, 06:04:34 AM »
Yeah, just you try and use the brakes.  I hope you scream well, cause you ain't slowin' down.
« Reply #34995 on: January 06, 2011, 06:07:38 AM »
 ;D Ain't that the #$%*in truth  ;D
        Vito Corleone
« Reply #34996 on: January 06, 2011, 06:52:55 AM »
Happy BDay CCH!
i hit that mark last week. it aint so bad.  :P
but the fkrs at work gave me a 40oz'er of Old E, a tub of Geritol, and a walker!!!  :D
Offline 333
  • Time for change
« Reply #34997 on: January 06, 2011, 07:23:29 AM »
Okay, not to monopolize the conversation, but back to beating a dead horse my chimney issues.  Yes, opening a window solves the "problem", but when it lets in more cold than the fire makes heat, it sorta defeats the purpose of a fire.  I've been told about venting, and you all are confirming this.  Maybe I'm Googleing the wrong thing, but I can't find this answer on the internet.  And yes, a vent is code around here these days, but my house turns 56 this year.  It wasn't an issue when Mom and Dad bought the house new, but after 20 years or so he had blown in insulation installed and then replaced windows.  It wasn't a big problem right after that, so if you had a fire upstairs, you really wouldn't notice unless you went into the basement.  If you burned one all day, smoke would eventually reach upstairs, but Mom never did that.  And the exact opposite would happen.  You burn one in the basement, smoke would appear in the living room.  The smoking would be considerably worse in either direction if you run the clothes dryer.
Oh, and TOTP Ma.
Offline Raef
« Reply #34998 on: January 06, 2011, 08:01:13 AM »
If they are solid masonry and on an outside wall it would be fairly easy to core drill through  the back of the fire box and vent each.
If I had a couple pics I could give some more detail on how I would do it. You could probably do it your self if your not afraid of getting dirty.... I am black as coal sitting in a heat treat furnace as I type this...haha
Mark
« Reply #34999 on: January 06, 2011, 09:30:20 AM »
Chiminy talk???? Dont even get me started about my furnace. FYI it is a Ford and every time a tech comes in to service it they say "Wow, dont see these anymore"
now for the jukebox. Here is my quarter. (no that is not me in the vid)
