Author Topic: Getting back on the road - small parts question  (Read 1219 times)
Offline Hutch
  • 1982 CB650SC
« on: September 24, 2018, 04:34:46 PM »
I'm finally in the home stretch of getting my 1982 CB650SC back on the road.  I'm missing the following parts, and they appear to be unavailable online.  Can anyone provide a recommendation for a source, or alternate/cross-referenced part number?
Clutch cable adjustment bolt - BOLT, CABLE ADJ.  53192422000
Petcock filter - SCR SET, FUEL STRN 16952425005  ***this is from a 1980 CB650 tank, I swapped tanks
Battery terminal nuts &  bolts - I'm not sure of the size, or what material is acceptable.
Also, does the fuel line typically run right from the petcock to the brass fuel joint between carbs 3 and 3?  I don't have the vacuum-assisted petcock.
Thanks all!
Online Kevin D
  • SE Michigan
Re: Getting back on the road - small parts question
« Reply #1 on: September 24, 2018, 05:40:32 PM »
Cable adjuster here at CycleReCycle in Indianapolis under general accessories $2.95
https://newmotorcycleparts.net/accessories/general_accessories.html
Screen set here at CMSNL, that's the Netherlands, only 2 left, € 30 sorry.
https://www.cmsnl.com/products/scr-setfuel-strn_16952425005/#.W6l7utEpChA
Battery bolts come with a new battery, maybe a battery shop will have some old ones, or new ones.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline irish44395
« Reply #2 on: September 24, 2018, 05:58:35 PM »
you can get away with out the auto fuel valve. I don't
use the one on mine just put the fuel line straight to the carbs . I also have a fuel filter in that line ,the one in the fuel valve has rotted away . hope this helps
Pete
