Author Topic: The Fightin' Terp K0 * RUNNNNNNNNNEEEEEERRRRRRRRRR. 12/28  (Read 18767 times)
Re: The Fightin' Terp K0
« Reply #50 on: October 03, 2018, 03:27:34 PM »
Found my receipt, but only has the bearing number on it. Here are the pics of the box numbers which may be what you are looking for. The first is the carrier bearing followed by the rear wheel and then front bearing.
Thanks.  The front FAG bearing is available on Amazon!
https://www.amazon.com/FAG-6302-2RSR-C3-Clearance-Rotational-Capacity/dp/B0051OZPKK
Offline Tews19
  • I am no
« Reply #51 on: October 04, 2018, 07:29:49 PM »
Nick, Shoot me a PM when you have it ready for a ride. I would like to get at least one longish ride on the 750F before it gets to cold and a trip up to Wisconsin and back would be perfect.
I will Danny. I'm really hoping the new fork seals come in tomorrow. If they do. Hopefully it will be put back together by Saturday.
1970 Honda CB750 survivor.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #52 on: October 05, 2018, 08:38:59 AM »
The local Dainese store in Chicago is hosting a group ride up into Wisconsin on Saturday, but from what I can see the weather is not going to cooperate.
I would be up for a ride the weekend after this one. By that time the trees in Southern WI should be in full Fall color mode.
« Reply #53 on: October 05, 2018, 09:25:41 AM »
I would think about coming over to ride with you guys
Offline Tews19
  • I am no
« Reply #54 on: October 06, 2018, 05:36:44 AM »
Sean the weather is suppose to be just awful till Thursday here. If the projected forecast changes for the following weekend, a ride may be possible. As of right now the bike won't be on the road due to the idle jet breaking off inside the carb body. I'm going to see if it can be easy out however there is nothing to grab onto.
« Reply #55 on: October 06, 2018, 08:31:30 AM »
damn, that is a real pita...turns out I have to work Saturday anyway.  Trying to plan a ride in advance is dicey this time of year.  I saved some vacation for sneaking in that last good weather trip before winter sets in but I have pretty heavy work obligations for the next couple weeks.
Offline Tews19
  • I am no
« Reply #56 on: October 06, 2018, 12:58:22 PM »
I was able to remove the broken jet without causing damage. Now back to cleaning the carbs!
Sent from my SM-G955U using Tapatalk
« Reply #57 on: October 06, 2018, 02:48:20 PM »
Ha!  The ole peanut butter trick!
Offline Tews19
  • I am no
« Reply #58 on: October 06, 2018, 05:50:39 PM »
Lol, I was wondering what the peanut butter comment meant. That's my step dad's work bench.
Offline Tews19
  • I am no
« Reply #59 on: October 22, 2018, 02:49:52 PM »
Quick update. The carbs are syncd, timing is on point, valves done. I was able to take it for a spin today. Smooth riding however there is an oil leak. I think it may be from the bottom cylinder gasket. Other then that she is running smooth.
« Reply #60 on: October 22, 2018, 03:05:37 PM »
Beautiful!
Offline Prospect
« Reply #61 on: October 23, 2018, 07:03:48 AM »
I like your garage floor.  Polished concrete or sealed?
That's a fantastic looking K0!
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #62 on: October 23, 2018, 07:35:26 AM »
Nice job Tews!    Was wondering how long it would take you to get it back together?!  Ha
Offline dhall57
« Reply #63 on: October 27, 2018, 02:36:33 PM »
KO looks good out on the road Tews. How bad is the leak, Hope it's just a little seepage like a lot of these sohc4 750's have.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tews19
  • I am no
« Reply #64 on: October 27, 2018, 05:34:14 PM »
It's not bad. However when it comes to small things like this, i'm anal. If I don't find cases for the number on my frame, I'll do a tear down.
Offline stou
    • Stoudesign
« Reply #65 on: October 28, 2018, 08:38:22 AM »
Wow! Very nice bike!  8)
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
KTM 890 Adventure R 2021
My CB750 build: http://forums.sohc4.net/index.php/topic,174710.0.html
Offline Johnie
« Reply #66 on: October 28, 2018, 09:23:50 AM »
Tews we got KO twins. She is looking great on the road.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #67 on: November 04, 2018, 09:30:23 AM »
Time to take the engine out and do some sorcery....
This is how she sits at the moment. I found a stamped engine that is within 1k of my vin. The plan is to swap the head and call it a day. Depending how the tear down goes, I may swap the cylinders and pistons but I'm hoping not to go that far.
« Last Edit: November 04, 2018, 09:32:49 AM by Tews19 »
Re: The Fightin' Terp K0 *Engine removal 11/4
« Reply #68 on: November 04, 2018, 11:27:59 AM »
The K0 often leaks oil near the shifter because there was no rubber plug in the countershaft oil feed passage, as was found in the later bikes. BUT - the plug fits, if you can find one, and stops the leak while improving the oil direction to the shaft!
Offline Tews19
  • I am no
« Reply #69 on: November 04, 2018, 11:29:47 AM »
Hey Mark, it's not leaking near the shifter. Its under cylinder 4 where the cases mate w the cylinders. Just an awful leak where I couldn't let it be.
« Reply #70 on: November 04, 2018, 06:54:12 PM »
 Some of the early ones used 450 fork seals, mine did. This looks like an awesome find, it was taken care of better than what I usually turn up.
« Reply #71 on: November 04, 2018, 06:58:47 PM »
I haven't seen one leak there before? Sometimes I see 'leaks' by cylinder #1 base, but it is actually caused by weeping from the cam chain tensioner that creeps along the base gasket and just shows up there, instead.
Offline Tews19
  • I am no
« Reply #72 on: November 06, 2018, 03:46:43 PM »
Progress!!! I tried the jig HACKOFTHEWEEK made and that was an epic fail. I had to wait for my 2 boys to get home today to remove and install the proper K0 engine into my bike. I figured it would be smart to see how the proper engine runs before I tear it down. Tomorrow hopefully I can hear it run.
« Reply #73 on: November 22, 2018, 10:54:38 PM »
 I run a lifting strap under the case between the points cover and clutch cover then under and back up in front of the dyno and over the starter pocket. Then I take one end through the loop on the strap to choke it up tight, I use my light duty chain hoist and lift from the right side, It usually lifts pretty level and is easy to handle by myself.
Offline Tews19
  • I am no
« Reply #74 on: December 03, 2018, 06:50:15 PM »
I made some time today to tackle tearing down the proper numbered case engine for my K0. Hopefully I can free up some time tomorrow  to split the cases and have them cleaned up. This may sound dumb, but am I able to reuse the piston clips or is it better to replace them?
