Author Topic: The Fightin' Terp K0 * RUNNNNNNNNNEEEEEERRRRRRRRRR. 12/28  (Read 21063 times)
Re: The Fightin' Terp K0 *Engine removal 11/4
« Reply #75 on: December 21, 2018, 06:39:12 AM »
How 'bout an update Tews?!
Or nothin' done cuz you been too busy at the Mall buying all those kids presents?!!!
Offline Tews19
  • I am no
« Reply #76 on: December 23, 2018, 11:40:35 AM »
I dropped the top case off to Adam Milazzo. He does aluminum welding and has bailed me out before with some exceptional work. Once the repair is completed I will get the cases blasted.
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
« Reply #77 on: January 30, 2019, 03:55:50 PM »
I picked up the top case, the repair was excellent of course. The past few days i was able to strip the lower case of all the internals. Upon inspection and help from JamesSussex I realized the bolt that is near the sprocket cover was broken. Not one but both. Looks like the PO forgot to mention that to me. Luckily was was able to pull the half assed drilled one out and the other one came out with vise grips.  The cases are with my mom's husband to do the thread repair.
Offline Tews19
  • I am no
« Reply #78 on: March 23, 2019, 01:31:17 PM »
Another small update on the slowest engine rebuild.. This is prior to the final rinse.
Sent from my SM-G955U using Tapatalk
Offline bek1966
« Reply #79 on: March 23, 2019, 06:59:32 PM »
Looks great Nick.  Can't wait to see it progress from here!
Brad
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
1975 CB550 F0 - Someday "ProtoSport"
Pleasant Prairie, Wisconsin
Offline Tews19
  • I am no
« Reply #80 on: March 24, 2019, 07:24:48 PM »
Brad
Thanks Brad.
« Reply #81 on: March 25, 2019, 07:48:34 AM »
Fantastic
Offline Tews19
  • I am no
« Reply #82 on: April 09, 2019, 12:41:13 PM »
Process today as I was able to remove the top end. Found the reason why she was pissing oil where the cylinder meets the top case. The base gasket seems huge! Inside of the lower case in almost every cylinder area. I'm not sure what to think of the cylinders. They look score but they are smooth.
Offline Tews19
  • I am no
« Reply #83 on: April 09, 2019, 02:14:21 PM »
Could it be a stock gasket but bored pistons and cylinders?
I'll measure Cal however it looks like maybe it shifted or the incorrect gasket?
Side note I talked to the son of the original owner and he said the cases were swapped out literally after he got it in 1970 due to the chain. Also the shop where the bike was bought new, cases swapped out is still open in Maryland. The shop is Pete's Cycle.
« Reply #84 on: April 09, 2019, 03:13:14 PM »
Could it be a stock gasket...
Looks black, not stock.   You might be able to get away with honing, can you measure the bore?
BTW - get rid of that couch and you will have room for a blue 550!
Offline Tews19
  • I am no
« Reply #85 on: April 09, 2019, 03:55:49 PM »
Lol, there is now 2 leather couches in that spot. I'm about to put on FB for free to someone in need
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #86 on: April 09, 2019, 08:54:52 PM »
It's all Bad Tews, send it all to me and I'll get rid of it for you..
Offline Tews19
  • I am no
« Reply #87 on: April 10, 2019, 03:04:30 PM »
Cases have been split! Tomorrow will be the day I plastigage the crank in the new cases. Any tips from anyone on how to go about the plastigage procedure?
Offline BPellerine
« Reply #88 on: April 10, 2019, 06:40:10 PM »
tews,as I found out those markings on the rods are japanese symbols,there is a table somewhere for checking bearing size on these,maybe a member has one,later rods had ink markings on them.bill
1978 CB 750K ard and webers
another anfob
Offline Tews19
  • I am no
« Reply #89 on: April 10, 2019, 06:52:45 PM »
Thanks Bill, they are Japanese markings after doing some research and a member on here reached out with the list.
Side note, I ordered the Engine oil seal kit from Vital. If I recall he is a member here and also makes the oil pump kits as well.
Offline Tews19
  • I am no
« Reply #90 on: April 11, 2019, 11:15:05 AM »
The most pressing issue for me was the lack of know how when it came to plastigage. Today i swapped in the brand new Black bearings Hondaman suggested and they all measured equally across the board..
.038 If I recall correctly, these are within limit and I can now move on to reassembly! As of now the biggest hurdle is crossed!.
Offline Tews19
  • I am no
« Reply #91 on: April 17, 2019, 12:27:21 PM »
Acetone wipe down, primered, and first coat of paint on the proper case K0 engine. The paint is freshly sprayed and will receive the last coat once this coat is dried.
Offline bek1966
« Reply #92 on: April 17, 2019, 02:19:08 PM »
Looks good Nick.  I especially like your supervisor!
Brad
Offline Tews19
  • I am no
« Reply #93 on: April 17, 2019, 02:36:54 PM »
Last coat applied. Time to cure.
Offline Tews19
  • I am no
« Reply #94 on: August 08, 2019, 02:37:44 PM »
Well this project has been pushed aside so many times this summer. The bike market has been flooded with gorgeous survivors and I have been finding a few hence why this K0 keeps being put on the back burner many months. I recently came across a few nice bikes to include the elusive Sandcast which I shared with a few members here. My latest find was the immaculate 400F and now I am the owner of a nice survivor 75 Z1.
Anyways, this K0 has my attention again and the engine was mounted today with the help of my oldest son. Covers will be mounted hopefully over the weekend. If anyone has a K0 tach, I'm looking to purchase one. I threw in 2 pics of the Z1. Currently rims are removed as the new Avons are being mounted and balanced.
Congrats and welcome to the Z Club!
Now throw that seat in the bin!
Offline BenelliSEI
  • 1969 cb750
Before you wax, ask your friend the painter about clear coating. I’ve often thought that would be the best way to protect such a perfect, original finish. After that, wax away!
Offline Tews19
  • I am no
Clear coat what? I'm lost
Online PeWe
That seat is really ugly! But wait 20 years and they might cost a fortune when people want them again ;)
A fresh stock seat on that bike look relly good with everything else in good condition. Z1-900 is probably the most beatiful bike of the 70's. 80's..... Shape of tank, side covers and the fastback is perfect. Stock type graphics too.
They cost a lot here, $10.000-20.000 US, the latter in perfect stock look. I need 2 of those, one stock, the other with hot engine and 4-1 (the hotter one can be a z1000-77 with the 1015 engine)
« Last Edit: August 09, 2019, 03:35:44 AM by PeWe »
Wow, that Z looks good.  Time to sling that seat on ebay!
