Author Topic: CB500 vs CB550 Cam  (Read 1301 times)
Offline motogotro
CB500 vs CB550 Cam
« on: September 28, 2018, 07:20:33 AM »
I have a 73 cb500 with a badly pitted cam lobe.  Will the cam out of a cb550 work in the CB500?  Any issues with that?
Re: CB500 vs CB550 Cam
« Reply #1 on: September 28, 2018, 08:24:30 AM »
Same part number same cam
Offline cb650
« Reply #2 on: September 28, 2018, 01:04:30 PM »
or do the 650 cam swap
Offline motogotro
« Reply #3 on: September 28, 2018, 01:47:37 PM »
Is there a benefit to the 650 cam swap?
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: September 28, 2018, 02:50:47 PM »
That reminds me.  I still owe you some PBR.  ;D
Offline calj737
  • I refuse...
« Reply #5 on: September 29, 2018, 03:10:24 AM »
Its a bit healthier. But, you need the tach drive gear for the 650 cam, AND your tach gauge will need to be swapped as they have different ratios than the 550/500. A 750 gauge is compatible with a 650, but not the cams.
« Reply #6 on: September 29, 2018, 03:57:36 AM »
be sure the lobes don't foul the cover or head aswell as the underside of the rockers,some clear,some may need clearancing.
« Reply #7 on: September 29, 2018, 04:13:42 AM »
By healthier...that being it will have more lower and mid-range torque and power with some more power at top end. The duration being mildly longer than the stock cb500/550. Electronic tach would be your other option over a mechanical cable tach.
Offline CarbonK
« Reply #8 on: September 29, 2018, 04:09:00 PM »
If you do go the 650 cam route, I got a camshaft and drive gear for sale.  ;)
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: September 29, 2018, 05:22:02 PM »
I can only speak to my personal experience and "seat of the pants" dyno, so take this with a grain of salt.  I did the 650 cam swap in my 550K2 about ten years ago.  It made no noticeable difference in town, but on the open highway above 6K rpm, when the stock engine would begin to plateau, it just kept wanting to go.  It felt a lot more like my former 400F that always just wanted to go faster.  A while later I switched to a 1-tooth smaller drive sprocket, and that really brought it to life.  It's not a long-range, long-ride bike, but that's what I have the 750 for.
« Reply #10 on: September 29, 2018, 11:22:40 PM »
Ha,if the 650 cam in your 550 reminded you of your 400 id skip it.
