Author Topic: Cb550f timing no test light  (Read 1884 times)
Offline JDillon
« on: September 29, 2018, 02:30:32 PM »
Doing a timing check, cam chain, valves before syncing my carbs and my test light will not come on! I tested it right up against battery, its new and works. I can tell points are opening right at the F mark by pulling  a piece of cigarette paper from between them, but is there any reason my test light wont go on when connected??
I just dont wanna have to dig in to wiring just yet...
 the bike still starts and runs but is rough do to only bench synch
Offline Robbo
« Reply #1 on: September 29, 2018, 02:40:02 PM »
Silly question...when testing, do you have the key turned to on and kill switch in run position?
1973 CB350 Four, 1975 CB550K
Offline JDillon
Re: Cb550f timing no test light
« Reply #2 on: September 29, 2018, 03:07:18 PM »
Oh man that is really humbling! Thanks! I definitely had the key on but the  killswitch not set to run... for some reason I totally overlooked that.. thanks again!
