Author Topic: Dimmer high/low fix  (Read 2470 times)
Offline Hutch
  • 1982 CB650SC
Dimmer high/low fix
« on: September 29, 2018, 06:25:44 PM »
Can anyone tell me if its possible to rebuild the dimmer high/low switch.  More specifically, the small copper contact plate with the spring underneath is not making good contact with the wire contacts.    As a result the head light wont stay on.  I've attached pictures for reference.
The first pic is the copper plate that is the problem, the second is of the wire contacts.
« Last Edit: September 29, 2018, 06:28:14 PM by Hutch »
Offline CBJoe
Re: Dimmer high/low fix
« Reply #1 on: September 29, 2018, 08:32:35 PM »
Cant see clearly..but can you "open" the plate on the movable piece back up so it makes good contact again?
Also...I love this stuff for oxidation...  http://store.caig.com/s.nl/sc.2/category.188/.f
The D5 if I remember correctly
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Hutch
  • 1982 CB650SC
« Reply #2 on: September 30, 2018, 12:23:04 AM »
There's a spring under the plate that should help with contact, but unfortunately the plate seems too worn.  I cleaned all contacts, and tried adjusting the plate, it didn't help.  I was considering a bit of solder on the wire connection to effectively bypass the switch and make a permanent high beam connection.  Can anyone think of a reason this might be a bad idea?
Offline CBJoe
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #4 on: September 30, 2018, 05:36:19 AM »
I may have some switch parts left over from previous 650s I’ve owned.  I’ll be in the shop later today and will take a look to see if I have that piece
'65 CB77
'66 CM91 (C90'ish)
Offline Hutch
  • 1982 CB650SC
« Reply #5 on: September 30, 2018, 06:07:00 AM »
Thanks Joe!
Sent from my Moto G (5) Plus using Tapatalk
Offline CBJoe
« Reply #6 on: October 01, 2018, 05:11:23 AM »
Thanks Joe!
No go....found a few small pieces and parts, but not the piece you are looking for.  Ebay looks to be your best bet.
Joe
'65 CB77
'66 CM91 (C90'ish)
Offline Hutch
  • 1982 CB650SC
« Reply #7 on: October 01, 2018, 06:23:16 AM »
Thanks, I appreciate you checking. eBay it is!
