So with the current combustion chamber thinking a flat top piston and a closed chamber head seems popular, flattening out the valve angle would require a bigger bore to fit the valves in. How big can we reliably bore one of Mikes cylinders? Modern springs are light years ahead of what we used to use, I don't think springs are an issue.
The last big improvement in nhra pro stock was reducing deck height, bigger bore and shorter stroke which lowered the heads, that pulled in the intake runners close together to the point where you could look through the carb and see the intake valve. We could raise the intake port until it got into the rocker cover, maybe a bolt on intake manifold? We aren't talking a stock frame any more either.
