Author Topic: Bypassing Clutch Lever Switch, 1978 CB550  (Read 677 times)
Offline skinsfn36
« on: October 02, 2018, 11:59:58 AM »
Hey y'all
Trying to get my bike to the point where I can start it with the handlebar controls. The bike currently doesn't even have a clutch lever or cable on it, so I need to be able to bypass the clutch lever switch.
Whats the easiest way to do that?
I also think I am missing that diode that goes on the side panel by the voltage regulator.
Offline skinsfn36
Re: Bypassing Clutch Lever Switch, 1978 CB550
« Reply #1 on: October 02, 2018, 12:02:59 PM »
To add some more details.
Fresh rebuild all the way around.
I have the motor, battery, and wire harness on the bike, but only have the basics plugged into the harness. Regulator/Rectifier, battery, fuses, starter, key ignition and right side handlebar controls mostly plugged in.
Offline calj737
  • I refuse...
« Reply #2 on: October 02, 2018, 12:17:58 PM »
Is the solenoid wired in to the R control?
Offline Bodi
« Reply #3 on: October 02, 2018, 12:23:59 PM »
The solenoid should have a green/red wire connected to one of the bullets on its wires. The other one should be yellow/red I think, that's the power from the start button. So just ground the green/red wire to the frame or engine with a cliplead or anything: that bypasses the clutch switch safety and the neutral safety (which won't allow starting if the diode is missing). The start button should activate the starter no problem.
