Hello from Leicestershire UK,
Still riding my VFR at 70 years of age. Recently brought a 550 K4, it was a non runer sat in an outside lockup at our local dealer looking a bit worse for wear. They reckoned the starter motor was shot but it turned out to be the sprag clutch plus it looked like someone had attacked the wiring with an axe and reconnected it with tape. After a lot of fiddling and bypassing cut out switch I managed to get it running at 3K revs but it will not tick over below that so it's time to strip the carbs and give them a good clean. The idea is to get it running smoothly and then see about a better refurb.
