Author Topic: CB750K7 rebuild, bad sound from engine  (Read 8316 times)
Offline stou
    • Stoudesign
Re: CB750K7 rebuild, bad sound from engine
« Reply #50 on: October 16, 2018, 01:20:47 PM »
Thanks for the detailed explanation Brian. The primary gear I used to replaced the damaged one look in good condition. With the old chain, I tried to force the 2 gears to move separately and I never was able to do so. The other one was moving with only little force. So for now I think it will do the job. The season is almost finished here, cold and snow is only a few weeks away. I made major works on the front of the bike, so I will only ride to be sure every thing is ok after the build. Next winter I will take care of the primary gear!
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
KTM 890 Adventure R 2021
My CB750 build: http://forums.sohc4.net/index.php/topic,174710.0.html
Offline bear
  • Leeton in Australia
« Reply #51 on: October 16, 2018, 06:00:07 PM »
Good luck with it and enjoy the ride while you can.
Brian
Offline stou
    • Stoudesign
« Reply #52 on: October 17, 2018, 02:48:08 PM »
Thanks Brian!
I just finished to put everything back. No more noise!!!  ;D :D ;)
But I didn't have a chance to do a test ride, today it is rainy and cold, only 45°F. Tomorrow it will also be cold, 39°F. But Friday is suppose to be not to bad, near 60°F with a mix of sun and cloud. That will be good for a road test!
I don't know if the jetting will be ok with the 836. Right now the carbs, jets, airbox are stock. IF I can ride a little bit, I will be able to look at the spark plugs.
I took many pictures of the build. When I'll have some spare time, I'll do a thread on that build!
Thanks for all your comments!
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline Tracksnblades1
« Reply #53 on: October 17, 2018, 06:53:00 PM »
Thanks Brian!
👍 Well Done!
Age Quod Agis
Offline stou
    • Stoudesign
« Reply #54 on: October 17, 2018, 07:29:07 PM »
I should have written, thank you all for your comments!  ;)
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
