Author Topic: custom wiring harness question using M unit blue  (Read 1106 times)
Offline algophobe
« on: October 09, 2018, 12:33:17 am »
i'm trying to go over my custom wiring for a cb750 k2 set up with m unit blue. possibly having some issue with adequate recharging of the battery. in comparison to numerous other wiring diagrams, does it matter if the 15A fuse is between the return (charging wire) from the rectifier to the battery? or should it hook directly to the battery?
second questions is if there needs to be any mods to the charging system if you switch to lithium battery? i'm using an 8 cell antigravity.
« Last Edit: October 09, 2018, 12:35:39 am by algophobe »
Ducati Hypermotard 950 SP 2020 "Percolo"
Honda cb750 café 1972 "Satmui"
Kawasaki zx6r 2005 "Garuda"
Kawasaki zx7r 1998 "Dharma" (stolen)
Honda Magna V4 1982 (sold)
Offline calj737
  • I refuse...
Re: custom wiring harness question using M unit blue
« Reply #1 on: October 09, 2018, 03:36:45 am »
No, and no.
The only involvement the M-Unit has with the charging system is to use the RR BLACK wire connected to LOCK or AUX for battery reference.
Offline algophobe
« Reply #2 on: October 09, 2018, 09:32:01 pm »
some one mentioned using Ricks special rectifier/reg specific for Li ion batteries. does that even makes a difference? I guess according to their website, its specifically set for Ballistics Li batteries.
« Last Edit: October 09, 2018, 09:34:17 pm by algophobe »
Offline shads
« Reply #3 on: October 09, 2018, 11:59:48 pm »
I thought that a R/R that is compatible with Li ion batteries is needed to prevent too high a voltage when charging.
Offline calj737
  • I refuse...
« Reply #4 on: October 10, 2018, 03:32:23 am »
Yes, it can. They have a new 14-100 model (iirc) specifically for Lithium batteries.
True, and, Lithium batteries have a different charge curve that the standard RR doesn’t map perfectly well to. New battery technology, new compatible charging technology.  :)
Offline algophobe
« Reply #5 on: October 10, 2018, 01:39:37 pm »
So could be the cause of premature battery failure like in my case with a regular RR
Offline calj737
  • I refuse...
« Reply #6 on: October 10, 2018, 02:43:08 pm »
Possible. Not likely though. I’d suspect a bad ground from RR or a poor reference on BLACK to battery POS.
Once you get a fresh battery, runs some voltage tests:
Electrics off, voltage at battery
Engine at idle, voltage at battery, AND voltage on LOCK
Voltage between RR BLACK and battery POS (measures difference in battery reference)
Voltage at battery and LOCK with motor at 4,000 RPMs.
Offline algophobe
« Reply #7 on: October 10, 2018, 09:59:14 pm »
Quick question, when checking the voltages in this location the black on the volt meter would be on ground? And the red on the meter would be at these various locations?
Offline calj737
  • I refuse...
« Reply #8 on: October 11, 2018, 03:21:51 am »
Yes, except for the test between RR BLACK and battery POS. (Bike not running)
