Author Topic: Head gasket  (Read 744 times)
Offline emlupi
Head gasket
« on: October 10, 2018, 06:34:59 am »
Good morning,
I have a 1972 CB750K2 that is all stock and running well. Recently I have noticed that there is a very light oily sheen appearing around the perimeter of the head gasket after riding. It looks like oil is slowly wicking through the gasket. This only happens while the motor is running. It doesn’t happen while the bike is sitting. It doesn’t drip or run, it just gets a little damp around the gasket.
The bike had sat for many years before I owned it so I’m assuming that the gasket has deteriorated and is now beginning to leak? I guess this means that I will soon be looking at doing a top end rebuild.
Anyone else with a similar experience or advice I would be happy to hear from you. Thanks
Offline beemerbum
Re: Head gasket
« Reply #1 on: October 10, 2018, 08:14:58 am »
My 1977 K7 does the same thing as well as the cam cover. Not even Soichiro could install gaskets that would last 40 plus years in an air-cooled motor.
Online PeWe
Re: Head gasket
« Reply #2 on: October 10, 2018, 08:33:21 am »
Tighten the head nuts demands so much work. Very heavy too if frame has no frame kit :(
Tighten them might help.
CB750 K6-76 1005cc JMR Billet block.
Re: Head gasket
« Reply #3 on: October 10, 2018, 09:21:31 am »
If it aint soaking your riding pant leg(s), its not worth the trouble.
Wipe it down after a ride, and check that your oil tank is topped off.
...you can also get a few feet of cotton rope, to push in between the fins around the gasket seam.
Change it every so often.  That'll buy you at least a year  ;D
Offline emlupi
Re: Head gasket
« Reply #4 on: October 10, 2018, 01:04:03 pm »
Thanks for the replies. It is not really losing that much oil. I check it after riding and the last time it was down about 4 ounces after 300+ miles. Definitely not making any mess. I only noticed it while giving the bike a good wipe down after riding. I guess I will keep an eye on it but plan to eventually go in and make repairs.
