Author Topic: CB 750 SOHC to DOHC swap  (Read 1769 times)
Offline olasek18_18@o2.pl
« on: October 11, 2018, 05:20:44 am »
Hello, did someone try to put DOHC motor from CB 750K 1979-1982 to CB750SOHC 1969-1978 Frame? is it possible?
Offline beemerbum
Re: CB 750 SOHC to DOHC swap
« Reply #1 on: October 11, 2018, 09:42:34 am »
Why would you?
Offline lrutt
« Reply #2 on: October 11, 2018, 10:34:02 am »
Why would you?
Kinda what I was thinkin
« Reply #3 on: October 11, 2018, 10:52:50 am »
 The 750 motor mounts are the same, at least for a few years. I'm unsure about the height. We usually prefer to go the other way, putting a sohc into a newer frame. The reason we're here is we think the single cam engine is better.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline beemerbum
« Reply #4 on: October 11, 2018, 01:20:33 pm »
Its the appearance of the SOHC motor that is so appealing. The DOHC looks just like any other UJM
« Reply #5 on: October 11, 2018, 03:38:54 pm »
'74 "Big Bang" Honda 750K [836].....'71 Honda 750K project.....'76 Honda 550F.....K3 Park Racer!......and a Bomber!............plus plus plus.........
« Reply #6 on: October 12, 2018, 02:16:16 am »
Thank you, convinced me! :)
Offline Henning
« Reply #7 on: October 12, 2018, 07:08:31 am »
Ha ha, I always thought it was because the SOHC engine is rock solid and the DOHC is rubbish, but I suppose that's right. I need to look on the bright side next time I need to set the tappets or change the plugs.
71 or thereabouts 750 K1 - this one should have been put down
