Author Topic: Which one for which one  (Read 2179 times)
Offline Can550
« on: October 11, 2018, 02:25:39 PM »
If someone could please identify which element for which year. I know one is up to 76 and other one for 77/78 cb550k
Don’t recall which year takes taller one.
Thanks
Offline BRG-BIRD
Re: Which one for which one
« Reply #1 on: October 11, 2018, 04:43:36 PM »
Seems like my 75 takes/has the taller one.
“You are either on something or onto something.” The Comman Man
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #2 on: October 11, 2018, 08:14:03 PM »
yup the shorter one is for the 77/78
Offline Can550
« Reply #3 on: October 11, 2018, 08:36:03 PM »
Thanks
Offline Deltarider
« Reply #4 on: October 11, 2018, 11:42:13 PM »
If you have the original Honda air intake, I wouldn't use those breathers at all, as it will most likely humidify/foul the paper airfilter element. Some turned to inferior filters like Unifoam only to face other problems, others simply closed the breather intake and have the tube rerouted as shown on p. 170 of the Honda Shop Manual CB500 - CB550.  https://www.classiccycles.org/media//DIR_1653304/DIR_1653404/DIR_1653507/ecc6759db0a214d5ffff8825ffffe41e.pdf  BTW, this will not affect performance in anyway.
« Last Edit: October 11, 2018, 11:50:14 PM by Deltarider »
CB500K2-ED Excel black
Offline Can550
« Reply #5 on: October 12, 2018, 07:51:55 AM »
Good point
Appreciated
Offline Smudgemo
  • Maker of Stuff
« Reply #6 on: October 12, 2018, 08:33:45 PM »
If you need a repo seal for the earlier one, let me know.  I ordered an extra by mistake.
https://www.claussstudios.com/store/c15/Honda.html
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
« Reply #7 on: October 13, 2018, 12:36:59 PM »
Good point
No, it's not.  It is a highly biased opinion without first hand knowledge.
The breather works fine for those that actually use it.  I do.  But, you must keep the foam insert from total saturation blockage in wet/cold weather and short engine run times.   Also, the drain tube needs to be kept clear and able to leak out collected water from the engine crankcase (which is highly desirable for good engine health).
The shorter one is the later design.  I've also seen earlier ones cut down by P.Os.  (Who didn't take routine bike maintenance seriously.)
Offline Can550
« Reply #8 on: October 13, 2018, 03:42:44 PM »
Thanks TT
always wealth of knowledge and good advice from you.
Offline Can550
« Reply #9 on: October 13, 2018, 03:43:14 PM »
Thanks but I’m good with rubber seal.
