So. Bike passed the inspection without any problems. Now I can ride for two years until the next inspection
I have worked a lot on the bike and it's 99% finished. The last thing to do on it is to plasti dip the orange color on the rear view mirrors, and also the bar end plug. The original exhaust will also be painted to look fresh.
Bike is also fully tuned for now. In the future my plan is to buy a full circle crankshaft 54mm (orig 52mm) from Malossi, port and bore the cylinder to 183cc, a racing exhaust and a reedblock from a RD350. Before I do that I need to buy a new crankcase (complete engine). I don't want to "destroy" the original one with hardcore tuning. That will get around 30-35 bhp. That's crazy for this little bike!
This is what I have done to the bike:
Frame, Wheels & Suspension- Cleaned the frame and repaired small rust spots
- Cleaned the suspensions, harder setting
- New bushings swing arm
- New bushing unknowing arm
- New custom made bushings (Deleon) for the steering arm (weak spot one these bikes)
- New paint on wheels
- Tricolor rim tape
- New valves
Brakes- New brake fluid
- Cleaned calipers and brake pads
Bodywork- Some new plastics
- Repaired plastics
- Painted all plastics
- Removed passenger grips (stupid construction)
- Home made rear bracket for tail tidy
- Tail tidy
Engine- Cleaned engine
- Jubilee Racing CNC head 12,5:1 compression (orig 9,8:1)
- New coil wire with D9EA spark plug
- New gearbox oil
- Polini Maxispeed variator with 16,0g rollers
- Polini aramid belt
- New oil pump belt
- Malossi green clutch spring (higher rpm clutch engagement)
- Dellorto Malossi 25mm carburetor
- Polini podfilter (earlier Doppler)
- Malossi boost bottle
- Stage 6 intakekit
- Stage 6 Reedblock
- Kundo exhaust (currently using the original since I have hard to tune in the Kundo, it only gives better sound..)
- New rubber hosing for the cooling system
- New radiator
- Voca Racing fan switch with 10 degrees lower activation
Electric- Led flow turn lights with brake function
- New blacked out front turn signals
- Smoked rear lens
I have certainly forgot something but that's almost all.
The bike hits 148 kmh on the speedo and with GPS 132 kmh. It has great acceleration also, easy to get it up on one wheel.
