Author Topic: Confusing manual for timing strobe...  (Read 3635 times)
migopod
« on: June 06, 2005, 01:57:12 PM »
I just picked up a timing strobe from sears, and it's a little odd in the instruction department.
It's an inductive pickup type, and it states in the manual that you connect the red alligator clip
to the (-) battery terminal, and connect the black clip to the frame.
The odd bit is that the (-) battery terminal does connect to the frame, and my physics class from
a few years ago suggested that in order to get any kind of current flowing, you have to have a
voltage differential between each end of the circuit...  This seems like it could be achieved by disconnecting
the negative terminal from the negative lead and putting the strobe in-line with the battery, but it didn't
suggest doing this. just hooking it right up to the terminal and frame.
Did they typo the battery terminal polarity, or should I put it inline between the battery and frame?
hooray for ambiguous documentation!
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Confusing manual for timing strobe...
« Reply #1 on: June 06, 2005, 02:11:48 PM »
Every timing light I`ve ever seen the red goes to + and the black to ground.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
migopod
« Reply #2 on: June 06, 2005, 02:44:30 PM »
That WOULD make the most sense...
i'll try it that way and see if i get the flicker.
Thanks!
Offline Raul CB750K1
« Reply #3 on: June 06, 2005, 02:55:22 PM »
If it is the inductive type, you need to connect it to positive and chassis to power it up. Then you'll probably need to place the inductive clamp around any of the high tension leads going to the spark plugs. The sensor will detect the high voltage and will make the xenon bulb to light.
The passive inductive light are connected in series between the spark plug and the ht lead, because they are simply a strobe light powered by the high voltage, that makes the spark weaker and the light is not very powerful. Inductive type are much better.
Raul
migopod
« Reply #4 on: June 06, 2005, 02:57:40 PM »
just so long as nothing needs to be attached to a ball.
Offline frostypuck
« Reply #5 on: June 06, 2005, 03:07:32 PM »
When they write the manual, they don't know what kind of car/ bike you're planning on using it on. Many newer cars discourage you from connecting anything to both terminals of the battery, as an errant spark may fry the car's brain. So in order to cover the lowest common denominator of wrenchers, they suggest connecting to the positive terminal and a bit of metal on the engine.
Also, that's the reason they suggest disconnecting the negative battery terminal first when changing the battery. If the battery isn't grounded to the vehicle, you can't cause a spark by inadvertantly touching a wrench to the (+) terminal and the fender.
Chris in Boston
Boston, MA, USA
Offline Robert
  • Sorry for my English
« Reply #6 on: June 06, 2005, 03:12:36 PM »
...for best results place the inductive clamp as near as possible to the spark plug connector.
Often the clamp has a "spark plug side", so you may want to give attention to that too.
Offline Clyde
« Reply #7 on: June 06, 2005, 11:35:19 PM »
I have an inductive unit and it is as per your instructions. The battery provides power to the inductive unit and and fires the xenon bulb. It is better to use another battery rather than the one in the bike, as you can sometimes get a false pulse from electrical interference from the motor.
The inductive clamps are sometimes directional. Look for an arrow or marking on the inductive unit.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #8 on: June 07, 2005, 06:56:08 AM »
Even with a plug attached to a ball I still can understand instruction manuals...  ;D
057 adnoh
« Reply #9 on: June 07, 2005, 02:09:46 PM »
hook the strobe up to you car battery , then put the inductive clamp on the bikes plug wire  if you get an erratic flashing from the strobe turn the iniductive clamp upside down on the plug wire . make sure you dont drape the strobe wire over the exhaust pipe ( let my lesson be yours!!!) good luck !!! ::)
eldar
« Reply #10 on: June 07, 2005, 02:13:31 PM »
That is the hard part with the plug wires between the exhaust. you almost need to tie the wires away from the pipes or use 3 hands.
migopod
« Reply #11 on: June 08, 2005, 07:57:22 AM »
I just wound up hooking red to + and black to frame (which i think the manual probably would have suggested.)  Maybe the
author had difficulty seeing vertical lines and was black/red color blind.  It worked very well indeed, and looping the wires
around the marker lights kept them from melting to the exhaust.
Thanks for the help
