Author Topic: Winterizing the bike!  (Read 4584 times)
Offline Dos
  • Owner of a cb350f
« on: October 16, 2018, 06:14:54 AM »
Hey guys, just getting ready to winterize my bike and go for my last couple of rides, seems to be getting colder each day here.
I usually coat the bike in wd-40 and take the battery out and have it on it’s center stand but do you guys leave gas in with some additive? Or completely drain the tank out and let it sit empty?
I know to drain the carbs just don’t remember whether the tank should be emptied or not. I have coated it in the past with the metallic sealer( forgetting the name)
Thanks, would like to hear how you winterize your bike.
Is it too early!? Haha I’m in NJ
Offline Can550
Re: Winterizing the bike!
« Reply #1 on: October 16, 2018, 06:29:57 AM »
I add sea foam in gas tank, go for a short ride, turn the fuel petcock off before reaching home, remove battery and put it on centre stand. Throw a blanket (that I had bought few from u haul) and wait for spring.
« Reply #2 on: October 16, 2018, 06:34:37 AM »
  Here in Michigan I don't really do too much. I pull the battery and keep it charged. I don't drain the gas out of the  tank or carbs or anything and find it usually picks up where I left off in the spring despite all the fuel horror stories out there. A friend of mine unclips/empties his float bowls on his 750 and lets them lay open on the engine case on his over the winter.
« Last Edit: October 16, 2018, 06:37:08 AM by ekpent »
Offline Deltarider
« Reply #3 on: October 16, 2018, 08:36:45 AM »
I agree with you. There are a lot of horror stories indeed. But, in spite of them, so far your experiences match mine. I do replenish the content of the floatchambers say every 2 months (I favour keeping them 'wet' during hibernation) but I seriously wonder if that replenishing is needed... So far never had a problem, not even after 7 months.
« Last Edit: October 16, 2018, 08:44:37 AM by Deltarider »
CB500K2-ED Excel black
Offline Dos
  • Owner of a cb350f
« Reply #4 on: October 16, 2018, 09:28:33 AM »
Yeah I usually just leave the gas in and drain carbs but for some reason my petcock leaked this season
Offline millla03
« Reply #5 on: October 16, 2018, 10:04:48 AM »
My experience is similar to what others have mentioned. I put some fuel stabilizer in the tank to match what gas is in it, drain float bowls, and pull the battery. Had carbs off spring 2017 during engine rebuild, and they showed no corrosion or deposits from this practice. There have also been a couple winters I didn't bother to drain the float bowls, and it didn't seem to matter. I use Honda fuel line and Viton o-rings in the carbs, which have held up fine to regular E10 fuel.
Bike lives in heated garage with minimal temperature change, so corrosion from hot/cold cycles isn't much of a concern. Tank is also lined so rust isn't an issue, though fogging it or topping off before storage isn't a bad idea if it is unlined. A good cleaning and detail in the fall is always nice too, just to get road debris and dirt off the bike. Then you have a nice shiny ride to start the next season.
Drop battery in, turn on the gas, and it always fires right up in the spring after sitting for 3-4 months.
Luke
72 Honda CB750 K2
78 BMW R100/7
83 Honda Nighthawk 650
07 Honda Rebel 250
« Reply #6 on: October 16, 2018, 10:04:55 AM »
I have my K6 in a warm garage, part of my house. Start it every 2 months or so, let it idle a minute or 2. Charge battery for 2-3 days every 2 months too. No risk it will rust.
« Reply #7 on: October 16, 2018, 10:51:16 AM »
In my garage, I empty the tank and carb bowls or add Stabil and plug in my Battery Tender. It's that simple.
Offline Johnie
« Reply #8 on: October 16, 2018, 11:22:10 AM »
In WI...bikes stored in my heated shop so no moisture issues. I put Stabil in the tank and take it for a ride. About a mile before I get home shut off the petcock. I do not pull the float bowls. The first of every month I put the Battery Tender on each bike. Come spring I open the petcock and ride them with no issues...ever. Works for me.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Dos
  • Owner of a cb350f
« Reply #9 on: October 16, 2018, 11:23:43 AM »
I don’t have a metal garage so it gets very very cold. Should I top the tank off with stabil/seafoam? Or just like half the tank?
Offline Deltarider
« Reply #10 on: October 16, 2018, 11:49:28 AM »
Not a good practice IMO. Two minutes of running - and then even idling, ouch! - is never enough to sufficiently warm up the engine and that as a consequence will lead to condens in the engine and I hate to think of what it does to the exhaust... If I were you I would suppress my desire to want to hear the engine run.
« Last Edit: October 16, 2018, 11:52:56 AM by Deltarider »
« Reply #11 on: October 17, 2018, 03:03:43 AM »
No problem in a WARM garage, 21-23C. Wintertime not that humid air either.
My bike has now a stainless exhaust so it will not rust. My old pipes did not rusted either, 4-1 from the 80's or later Yamiya 4-4.
Different thing if stored outdoors under a blanket or similar. Tank can start to rust inside and pipes too.
It might be worth it to take the bike indoors beside the TV  ;D
Or check for a good storage place. Rent a warm dry place with other bikers.
Or check bike shops offering winter storage. It might be a risk if the bike shop will go bankruptcy, bank comes and take everything in the shop. It can take time until the owners get their bikes back if they can proove that they haven't sold bikes to the shop
Offline calj737
  • I refuse...
« Reply #12 on: October 17, 2018, 03:39:19 AM »
Only enough to treat the volume of gas. BUT, either store your tank completely full or completely empty. 1/2 full provides air space for evaporation that will rust the underside of the tank. Do run the motor with Stabil/SeaFoam to treat the fuel in the carbs/bowls. And spin the back tire every couple of weeks to prevent flat spotting it.
Offline Old Scrambler
« Reply #13 on: October 17, 2018, 08:06:29 AM »
I stored my K3 in cold and damp storage for an entire year in Wisconsin with 110-race gas in the tank............started right up with the battery that I kept charged. Adapted the idea from friends with numerous bikes to store.  Fill a nearly empty tank and go for a ride. Leave the fuel in the bowls. This year my K3 is traveling with me.
« Last Edit: October 17, 2018, 08:10:23 AM by Old Scrambler »
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Pwrwagontom
« Reply #14 on: October 20, 2018, 07:10:32 AM »
I've always left a full/fresh tank of gas, filled with stabilizer; this keeps moisture from accumulating in the empty tank.  I close the petcock and run it out of gas, then put it on center stand.
CB750K2- Briar Brown Metallic
CB750K2
Offline jlh3rd
« Reply #15 on: October 21, 2018, 05:15:43 PM »
i've never heard of acid in wd 40. It's helps in removing rust,sure. But it's a water dispersant or displacement ,WD.....I've also never seen or read any directions on using wd 40 that say not to let it sit on chrome, metal, or painted surfaces....so it keeps water from reaching a metal surface, which is exactly what we're trying to do.
« Last Edit: October 21, 2018, 06:50:05 PM by jlh3rd »
« Reply #16 on: October 21, 2018, 10:04:30 PM »
 A bike I bought at auction appeared nasty and pitted but I had a parts bike for it at home and bought it anyway. Later I wiped a turn signal off and it was beautiful under the accumulation of garage dirt, so I cleaned the entire bike. It had been coated with blue coral wax on the paint and WD40 on all of the chrome. There is still blue coral coming out from under the chrome edges but that bike is awesome and I didn't replace anything. If it had been prettier I might not have gotten it. Did I mention it's a sandcast?
 I left some hidden wax on the back of the front turn signals to remember the PO by. He loved his 750 to the end.
Offline Deltarider
« Reply #17 on: October 22, 2018, 04:14:02 AM »
….remove the battery to inside temperatur …
Actually it's better to leave the battery in a cold place, provided it is well charged. The battery contains in fact a constant chemical proces and by storing the battery NOT warm, you slow down that proces, reducing the self discharge and so enhancing its lifetime.
« Reply #18 on: October 23, 2018, 07:41:43 AM »
Winterizing?   Riding season has just started down here!
Last weekend....
Offline Dos
  • Owner of a cb350f
« Reply #19 on: October 23, 2018, 08:16:46 AM »
Yeah I’ve got acouple more rides to go
Offline Erny
« Reply #20 on: October 24, 2018, 01:09:53 PM »
I'm actually in front of the same dilema.
I'll keep tank full of premium gas (100 octane Shell V Power Racing, with gas stabiliser), will empty carbs.
Bit wondering how to prevent rust on chrome parts and paint? And what about seat and rubber parts?
I can spray wd40 on chromed parts, but what for the rest?
I live in Europe, Slovakia, bike is kept in non-heated garage.
« Last Edit: October 24, 2018, 01:12:59 PM by Erny »
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline calj737
  • I refuse...
« Reply #21 on: October 24, 2018, 02:57:30 PM »
The seat and rubber parts shouldn’t rust, even in Slovakia  ;)
Offline Erny
« Reply #22 on: October 24, 2018, 03:09:27 PM »
You know what I wanted to ask - how to maintain them during winter, of course not due to corrosion
Offline jlh3rd
« Reply #23 on: October 24, 2018, 04:28:32 PM »
wax the painted parts, put viny/rubber dressing on the appropriate parts. wd 40 on chrome and other metal parts,spokes,chain etc..
       i don't have a heated garage, i have a full zippered enclosure with a battery maintainer and a small portable heater,and a big open box of baking soda as an absorbent,.. all in a shed......
      it works for me..
« Last Edit: October 24, 2018, 04:35:57 PM by jlh3rd »
Offline Deltarider
« Reply #24 on: October 24, 2018, 11:21:38 PM »
... and a big open box of baking soda as an absorbent.. all in a shed......
      it works for me..
Really?? As long as the shed is not 100% sealed, it will attract more moist. I've used soda in the cabin of my yacht during hibernation, only to find more funghi the next spring...
