Author Topic: Whose aftermarket handlebar controls are the best? Worst?  (Read 1695 times)
Offline Swoop
« on: October 16, 2018, 06:31:18 AM »
Looking to buy some for a 750 K0 and wondered about which suppliers provide the best product as an alternative to the oem ones? Which ones to stay away from?
Thanks
Steve
Offline Jonzilla
Re: Whose aftermarket handlebar controls are the best? Worst?
« Reply #1 on: October 16, 2018, 12:55:49 PM »
I got some Emgo for cheap and they look/feel/fit as good as the old stock bars.  Are pre drilled for wire routing too.
Edit: I misread your post...
'75 CB550K1
Offline calj737
  • I refuse...
« Reply #2 on: October 17, 2018, 03:34:39 AM »
Stay AWAY from anything branded "Emgo". It means "No-Go" for long. The quality is crap, solder joints are sh!t, and they tend to burn out rather promptly.
If you want "re-pop" controls, best to look at David Silver Spares, Yamiya, or Honda salvage contacts. Member Bill Benton often has a very broad collection of model specific spares. You can PM him.
Offline 540nova
« Reply #3 on: October 17, 2018, 03:57:12 AM »
Absolutely agree with everything Cal said, Emgo is well known for quick failures.
A good option is to buy any late model factory control, either from a dealer,  shop, or scrap yard.
I'm using Renard Speedshop custom switchgear, which are beautifully made, but pricey. Probably more challenging to wire than most would want to tackle,  as well.
Sent from my SM-G955U using Tapatalk
Offline calj737
  • I refuse...
« Reply #4 on: October 17, 2018, 04:08:24 AM »
These are the Bee's Knees for switch gear! Yep pricey, but well worth being on any non-stock ride  :)
« Reply #5 on: October 18, 2018, 03:05:29 AM »
I have seen old Honda controls people has restored. Look like new after cleaning, new paint and maybe some 2k filler before  paint.
Repair old bad ways of routing cabling outside, control got a huge ugly hole.
Offline Can550
« Reply #6 on: November 19, 2018, 04:32:26 PM »
Thanks
Steve
I may have a set complete or just casings polished or powder coated. If your problem is broken start button, I may have solution
Contact me, I’m in Brampton
Offline jakec
« Reply #7 on: November 19, 2018, 07:07:43 PM »
I've wondered about this, do you just paint the red lettering with a fine brush?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Can550
« Reply #8 on: November 19, 2018, 07:26:46 PM »
I filled red paint with a tooth pick once and second time with syringe needle as the hole holds paint
Online jaytee-nz
« Reply #9 on: November 19, 2018, 07:31:55 PM »
I just use a small brush and wipe off the excess with a fine cloth - just don't let the paint dry at all though. The trick is to go across (and not in to) the channels where the paint is so that the cloth only picks up the excess which has spilled over the edges.
Also, +1 on the Yamiya replacements - good quality, reasonable prices and fast delivery.
« Last Edit: November 19, 2018, 07:35:07 PM by jaytee-nz »
« Reply #10 on: November 20, 2018, 09:25:31 AM »
 I've used David silvers controls, I've also been lucky to find used ones and stockpile them for my bikes. The Chinese Honda replacement with the purple kill button worked OK and at least once I put the new parts from one in the old housing.
Offline jakec
« Reply #11 on: November 20, 2018, 10:15:37 AM »
I restored my right hand switch pod with the 3d printed starter button housing. I did not restore the outside though, which is a pale grey. My roommate put the replacement pod on his bike which can be found on 4into1 and has a plastic body. I would vastly prefer to restore the metal body and internals from honda than to go with the plastic bodied replacements.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
