Author Topic: Powder Coating  (Read 1758 times)
Offline Fourme
Powder Coating
« on: October 25, 2018, 01:09:36 PM »
So I recently purchased a 1972 750 and which I am in the process of restoring.
First timer, so taking it slow and reading this forum . . . .a lot.
My question is do you remove the VIN plate before sending the frame for powder coating and then rivet it back on, or just leave it?
Also, does anyone know a good shop for powder coating in South Texas (Austin/San Anton/Houston) area they could recommend.
Thanks,
Chris
Offline calj737
  • I refuse...
Re: Powder Coating
« Reply #1 on: October 25, 2018, 01:11:32 PM »
I’d encourage you to remove it. Carefully drill the rivets hot, use some monofilament fishing line, and slip it behind the VIN tag to release it from the neck. You can reinstall with new rivets after powder coating.
Offline Fourme
Re: Powder Coating
« Reply #2 on: October 25, 2018, 01:13:39 PM »
Good advice.  Thanks so much for the quick reply.
Re: Powder Coating
« Reply #3 on: October 25, 2018, 02:47:29 PM »
Hey Chris...are you in Austin? +1...remove the VIN plate. But, you will need special "rivets" to reattach it.
Diamond Powder in N. Austin is good....
16501 Bratton Ln
Austin, TX 78728
(512) 910-3976
Offline Fourme
Re: Powder Coating
« Reply #4 on: October 25, 2018, 03:49:58 PM »
I live between Austin and San Antonio so that's definitely doable.  Thank you for the suggestion.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Powder Coating
« Reply #5 on: October 25, 2018, 03:51:12 PM »
Or you can media blast the frame and use POR15 on it. You apply it yourself. It looks great, tough as nails, repairable later, costs less.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline 540nova
Re: Powder Coating
« Reply #6 on: October 25, 2018, 03:59:41 PM »
16501 Bratton Ln
Austin, TX 78728
(512) 910-3976
Why special rivets? I always use ss pop rivets.
Sent from my SM-G955U using Tapatalk
Re: Powder Coating
« Reply #7 on: October 26, 2018, 06:12:34 AM »
16501 Bratton Ln
Austin, TX 78728
(512) 910-3976
*if you want the stock look
Offline pjlogue
Re: Powder Coating
« Reply #8 on: October 26, 2018, 06:49:49 AM »
I have never seen a pop rivet as small as the stock VIN plate rivet.  If you are going to have your frame powder coated the shop will sandblast the frame first which will destroy the VIN plate.  Drill out the small brass rivets and save the plate.  You can re-drill the holes after coating.  I haven't put my VIN plate back on yet.  I was thinking of using some very small brass picture frame tacks for the rivets if I can find the right size.
-P.
Offline calj737
  • I refuse...
Re: Powder Coating
« Reply #9 on: October 26, 2018, 07:18:56 AM »
I believe they are referred to as "drive rivets" (stock). There's plenty of pop rivets available in a small enough size, but after you drill out the stock units, you'll be oversized already. So a 1/16 or 1.2mm metric will work just fine. I like stainless rivets or aluminum. The aluminum are easier to install, never rust, and work just fine. The stainless look brilliant against a repro VIN tag.
Offline kerryb
  • Not a very
Re: Powder Coating
« Reply #10 on: October 28, 2018, 02:08:15 PM »
it is my understanding that Mcmaster-Carr sells the correct rivets to put the vin tag back on.  I read that on this forum somewhere.  Definitely take the tag off, there were many stories of woe when guys got the frame back with the tag "blasted" off.
Offline Fourme
Re: Powder Coating
« Reply #11 on: October 28, 2018, 05:20:08 PM »
Thanks everyone for the great feedback
Offline przjohn
Re: Powder Coating
« Reply #12 on: October 28, 2018, 05:29:15 PM »
There are reproduction plates available that will put your VIN on them. They are on Ebay all the time and they come with new rivets that have the correct look.
Offline 540nova
Re: Powder Coating
« Reply #13 on: October 30, 2018, 05:57:47 AM »
Unless it's a concours restoration,  just use alu or ss rivets.
Offline pmanning
Re: Powder Coating
« Reply #14 on: October 30, 2018, 06:44:32 AM »
Industrial electric motor rewind shops usually have the original style drive rivets needed to reinstall the VIN plate since they often remove and reattach or replace motor data plates.
Re: Powder Coating
« Reply #15 on: October 31, 2018, 06:33:20 AM »
 My powder coat guy assured me he could remove the plate. Even after multiple questions. After all, he does them all of the time for those Triumph guys in the Quad Cities. Then they blasted my data plate into dust. On a low number K0. !@#$%^&*(_+  oh, next they pounded the rivets in tight before powder coating it.
Re: Powder Coating
« Reply #16 on: October 31, 2018, 07:23:36 AM »
I bought rivets from McMaster, I think I have enough for twenty bikes or so.  Send me you address via message and I will mail you few.
Offline Radski
Re: Powder Coating
« Reply #17 on: August 21, 2019, 06:54:39 PM »
Old topic but I'm looking for a couple to put on my freshly powder coated frame... still have any?
1976/1977 Honda Cb750 "Odzilla"
Offline Radski
Re: Powder Coating
« Reply #18 on: August 21, 2019, 06:55:25 PM »
if not can you tell me the appropriate size?
