Author Topic: Convert disc to drum brake  (Read 3438 times)
Offline Markagnew
« on: November 04, 2018, 09:19:49 am »
Maybe a strange question as I am fully aware disk is marginally better than drum, however I have a cb750 f1 supersport and love the drum brake look... how easy is the change over and what do I need? Thanks guys, first post so please be gentle 😂
Offline 69cb750
Re: Convert disc to drum brake
« Reply #1 on: November 04, 2018, 10:58:13 am »
Are you familiar with Darwin's theory of evolution ?
You are tempting fate and may be a victim if you do this, the disk has twice or more stooping power then a drum, that why it is there.
« Reply #2 on: November 04, 2018, 11:05:33 am »
 :markagnew, do you mean front, back or both ?
 Not twice the power but it has advantages.
 Both can lock up the rear wheel , can the disc lock it up with half the effort ?
 I think big advantage is less fade with a disc.
Offline jaytee-nz
« Reply #3 on: November 04, 2018, 11:14:23 am »
"Are you familiar with Darwin's theory of evolution ?"
That's kind of rich coming from someone who rides without any protective gear as per your Route 66 post !
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: November 04, 2018, 11:18:03 am »
Careful now... the last time I made that reference the member got all bowed up and took his ball and left!  :o
It could probably be done, but there are a number of hurdles:
>The rear disk brake stay bracket is on top of the swingarm, while the drum stay bracket (K models) is on bottom. You could weld a bracket to the underside of the current swingarm or source a K swingarm. You'll need the drum brake hub (or the whole wheel) as well.
>The F disk brake lever is different than the K drum brake lever. I do not know if these are a direct swap.
>If you overcome the difference in the brake levers you'll also need the rear brake stay arm and the link arm from the brake lever to the arm on the rear brake plate. You made need the drum brake lever spring as well.
EZPZ  8)
TAMTF...
Wilbur
Projects:
                                           http://oldmanhonda.com/MC/wiring750K1.html
Sent from my Tandy TRS-80!
« Reply #5 on: November 04, 2018, 11:31:22 am »
first, op never mentioned whether he was talking about front or rear...if rear, why not just get yourself a k instead of an f
« Reply #6 on: November 04, 2018, 11:37:04 am »
Since they all had front disk brakes I thought it was clearly implied  ;) that the rear brake was being referenced...
TAMTF...
Wilbur
Projects:
« Reply #7 on: November 04, 2018, 11:42:50 am »
If you insist on stopping slower and hitting things you need a 450 twin complete front end
« Reply #8 on: November 04, 2018, 12:13:50 pm »
 Agreed, get an early K and a 450 drum brake front end.  Or an early drum brake 450 as a second bike.  A Black bomber is the best idea.
If you love it, set it free, if it stays it's probably one of my 750's.
« Reply #9 on: November 04, 2018, 01:08:54 pm »
that would do it...although imo, the stock disc brake set up is quite capable at stopping slow and hitting things already lol
Offline Markagnew
« Reply #10 on: November 04, 2018, 01:11:44 pm »
Sorry I am talking about the rear brake only! Main reason for not getting a K over my F is about £5000 difference!
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #11 on: November 04, 2018, 01:40:31 pm »
It shouldn't be too difficult to do the rear. You have to find the right parts. Wheel, brake, torque arm linkage and brake pedal.
I saw a guy one time at Vintage Days who had converted the front disc brake to drum on his 89 Honda GB500, because he liked the looks of a massive Fontana front brake...
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #12 on: November 04, 2018, 08:12:12 pm »
Mark you can probably  do a wheel   swingarm, and other parts swap if you cant find parts for a reasonable price.
 Then you need to weld the bushing to your frame.
 Hope you don't want to run your alloy plates..
Offline turkey4me
  • The closer you are the less you can see!
« Reply #13 on: November 05, 2018, 05:08:58 am »
Once you source a K rear hub, you'll need a 10 mm off set sprocket for chain alignment.   You will not be able to run a chain guard. Then you will need to weld a new brake tab on the foot pedal cam to get any leverage. Stopping power is quite poor.   I would not recommend it unless you have dual brakes up front.  I never use my rear brake.  It's really just a last resort if the front ever fails.
Offline lrutt
« Reply #14 on: November 05, 2018, 05:42:01 am »
A well setup 4LS front will put you on your nose. As for drum rear, no big deal as both disk and drum will easily lock the wheel. I'd love to have a 4LS front either from a Suz, Guzz, or Benelli. Or better yet, a rare Fontana 8LS.
« Reply #15 on: November 05, 2018, 06:39:51 am »
I saw front wheel converted to drum on CB750 at Barber.
Offline slikwilli420
  • Master of Disaster
« Reply #16 on: November 05, 2018, 06:48:06 am »
I never got the front drum conversion thing. Its such a quantum leap backwards. They are heavy and reduce the compliance of the suspension. You score points for looks, but a well set up front end with period iron discs and AP calipers looks even better and stops far better as well. In the day before there were good disc options, then OK, but now you can have better period stopping performance for similar money. Suzuki hubs aren't falling from the sky and the rest are far more expensive than that.
As to the rear, both the stock drum and disc were tremendously overpowered for the task, easily locking the rear wheel. The best rear brake is one you can all but stomp on and not lock the rear wheel. Realistically there is no reason to even use the rear brake, especially on the street unless you are a very aggressive rider and ride to the edge of the bikes ability.
« Reply #17 on: November 05, 2018, 07:17:56 am »
 I'd think there are a few K owners that would happily swap out a drum setup for a disc setup. Look for that guy. You might even get a couple bucks to boot!
 My dream bike has triple discs but that's just me lol.
« Reply #18 on: November 05, 2018, 08:58:25 am »
Rear disc diameter usually really huge on the CB750 F bikes.
Rear brake useful when riding very slow before redlights and parking areas. High speed not much help, risk to lock the rear wheel.
I have only the old good drum!
My friend’s Honda Super Blackbird apply rear brake automatically when using hand brake.
« Last Edit: November 05, 2018, 09:58:09 am by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline robvangulik
  • Honda Fourever
« Reply #19 on: November 05, 2018, 09:51:35 am »
That is to assist all those people who never learnt to ride their bikes the proper way, hairpins in the mountains wouldn't be rideable  without a rearbrake, going up as well as down, and like you wrote, in city traffic as well. If it wasn't useful, manufacturers would have deleted it long ago!
« Reply #20 on: November 05, 2018, 10:06:47 am »
That bike have rear brake to be used separate too ;D
When you mention it....
I live in a flat area but I remember bike holidays thru Austria to Jugoslavia and Italy. Plus one holiday via France to Andorra for a week then the mountain roads passing Barcelona.
Some small steep roads had very sharp corners. Just got it thrown into my face! :) Yes, rear brake is useful when keeping the bike while twisting throttle, sliding clutch and rear brake at almost at the same time, hand brake not possible then.
« Last Edit: November 05, 2018, 10:08:18 am by PeWe »
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #21 on: November 05, 2018, 12:58:54 pm »
Friend of mine who is used to ride Harleys, visited from out of State and I had him ride my R1100RT. he pointed out that I must have a problem with the rear brake, because he thought it didn't work properly. I checked it and it was fine.
Rear brake comes in handy when you stop at a light at an incline and you want to keep the bike from rolling back.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline robvangulik
  • Honda Fourever
« Reply #22 on: November 05, 2018, 05:05:32 pm »
Simply difference in weight distribution! :D
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #23 on: November 06, 2018, 01:41:56 am »
No use for the rear brake?  :o
You guys been sippin the macallan no.4 tonight?
Proportional braking is a good thing.
75 CB550F Bloo
03 DS650/720 Bombardier
76/78 XS750 Oscar the Grouch
07 FJR1300; Lydia
05 YFZ450/470 Stroker (sold)
73 Norton Commando 850 Cafe
99 Roadstar Silverado (rebuild)
Certified Harley Davidson Tech
« Reply #24 on: November 06, 2018, 07:20:20 pm »
How about one of these ?
 A bit over the top perhaps....
