Author Topic: Slow Jet Question - 73 CB500  (Read 449 times)
Offline toobad
« on: November 04, 2018, 08:21:40 PM »
I tore down my carbs today to check float level adjustments and noted a variance between the location of the four slow jets.  On the two carbs next to the choke lever, the slow jets seem to be in the correct location, i.e., to the left of the main jet.  On the other two carbs, the slow jets are to the right of the main jet.  Here is the deal, I noted this same issue when I rebuilt them completely about 10,000 miles ago.  However, I replaced the slow jets in the same location that they were in when I tore them apart.  I have been experiencing a lag in acceleration, hence, the float adjustment or possibly two slow jets in the wrong place.  I did purchase a handy dandy float level tool and have found out the floats were out.
So, here is my question.  Should all of the slow jets be in the same place (left of the main) or does it matter since the other two holes are threaded and seem to take the slow jets?  Thanks for any assistance.
Re: Slow Jet Question - 73 CB500
« Reply #1 on: November 04, 2018, 08:45:08 PM »
The slow jets must be on the side of the carb that has the air bleed pilot adjust screw.  That's why they are different between 1&2 and 3&4 positions.
« Reply #2 on: November 05, 2018, 02:15:39 AM »
You will also find that the casting is not machined for the jet on the "other" hole
Offline toobad
« Reply #3 on: November 05, 2018, 11:16:23 AM »
Roger that.  Makes perfect sense now.  Thanks for your assistance!
