Author Topic: Carb choke shaft end plates on carb 1 and 4...  (Read 465 times)
Offline shads
« on: November 05, 2018, 12:07:15 AM »
I'm in the process of putting my carbs back together and noticed that I only have one of the little blanking plates that goes in the holes for the choke shaft on 1 and 4 carbs.  I've looked back over my photos taken before pulling them apart and the plate was missing from carb 4 then also.  I assume there should be one at either end and if its missing is going to cause vacuum issues?  Does anyone have a spare one up for sale that could be posted to Australia?
Thanks guys
Offline pjlogue
Re: Carb choke shaft end plates on carb 1 and 4...
« Reply #1 on: November 05, 2018, 08:59:59 AM »
Shouldn't make mush difference as far as your carb vacuum.  It's upstream of the throttle slide where vacuum is initiated.  I would put some felt in there oil it and see if you can fashion a plug of some fort to hold the felt in.  Lack of a plug will allow dirt to get in and over time wear the shaft/hole all be it slowly as it really isn't much of a moving part.
-P.
