Author Topic: Starting Issues  (Read 596 times)
Offline Vintageguy
Starting Issues
« on: November 07, 2018, 12:06:05 pm »
My CB750 F has developed the issue of not starting on the starter button. It will start on the first kick, but I want it right. My high beam indicator (Blue) comes on when I push the starter button. My battery is full. Any ideas out there? Thanks.
Re: Starting Issues
« Reply #1 on: November 07, 2018, 12:25:14 pm »
Grounding issue?  IIWM, its time for a control cleaning.  lots of gunk can build up in there.
Offline Tracksnblades1
Re: Starting Issues
« Reply #2 on: November 07, 2018, 12:32:47 pm »
+1  she's looking for a ground. I'd check to see if you have any voltage at the starter relay too.
Age Quod Agis
Re: Starting Issues
« Reply #3 on: November 07, 2018, 01:23:55 pm »
An F should turn the lights off before the starte operates but the white plastic switch surround degrades with age and falls to bits. If it is this i am afraid you need a new complete switch unit as the internals dont come seperate
Offline Vintageguy
Re: Starting Issues
« Reply #4 on: November 08, 2018, 05:28:58 am »
What would no voltage at starter relay mean, please? (My guess is the switch is shot).
Re: Starting Issues
« Reply #5 on: November 08, 2018, 08:50:02 am »
Either that or a bad connection/broken wire. Dont forget later bikes work differently to early ones.
« Last Edit: November 08, 2018, 08:51:54 am by bryanj »
